CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
DVD RW Will Not Read Media
By Fireholder on Mar 17, 2008
LG GSA-H55L Super Multi Security DVD Rewriter with LightScribe™
Problem:
Does not read media of any type.
Windows errors:
Access denied.
Not a valid win32 application.
Details:
Shows in My Computer as "DVD-RAM Drive" until media is inserted. Then it changes to "CD Drive" with either "0 Bytes" listed under Total Size and Free Space, or nothing at all. This is regardless of media inserted. I've tried CD Audio, CD ROM, DVD ROM, DVD Movie (all retail) and the same issue occurs. Media disks are all clean with no scratches or smudges.
What I've Tried:
Uninstalling all optical drives from Device Manager, turn off PC, physically uninstall both drives (I also have an LG CD RW drive, no problems with that one in any case), reboot to confirm no drives present, turn PC off again. Install DVD drive as master alone, turn on to test drive. Same problems.
I've tried with the CDRW as master and DVD as slave, DVD as master and CD as slave, DVD alone as master, DVD alone as cable select. The drive has the DVD specific options in Device Manager (DVD Region, etc).
I have no virtual drive software installed. I have all current updates for operating system. I've done complete malware scans (AVG Professional and Spybot S&D). My BIOS is up-to-date with no problems in any other functions of my system. The CD drive works totally fine, read/write regardless of other drives or whether it is master or slave, so that eliminates the IDE channel or cable as the problem.
I bought this drive a few days ago to replace another one with the exact same problem, a LITE-ON DVDRW LH18A1P.
Since the problem has occured in identical fashion with 2 different drives, of 2 different brands (both DVD writers) I can only assume the problem is with my computer.
I've done extensive searches on the internet trying to find a solution, and keep getting the same "answers" with no positive results (usually that the drivers in XP SP2 are the problem).
I would very much appreciate any help with this issue, as it is VERY annoying, to say the least. I bought Call of Duty 4 (PC-DVD) and can't even install it. I can't watch any of my DVD movies or burn any DVD ROM disks.
My System:
ASUS P4P800-E Deluxe (motherboard)
Intel Pentium 4 3.0Ghz CPU socket 478 (Prescott core)
1.5 GB DDR400 RAM
Microsoft Windows XP Professional SP2 (legal copy)
Comments:
Apr 16, 2008
- no filters found, can you think of anything else?
May 01, 2008
- No filters found, same problem. Even tried re-installing my OS from scratch. The drive worked fine when I had it tested at the store where I bought it...
BIOS only shows it as ATAPI CD-ROM Drive, IDE interface...
but its model number shows as well. I updated firmware to latest released from manufacturer.
Same Problem
Jul 17, 2008
-   same prob as fireholder-   Guest
Jun 22, 2008
-   Identical problem to OP =/ Anyone solved it yet? -   Davrioza
Solution #1
posted on Mar 23, 2008
Somewhat Helpful)
latinmcgyver
Rank: Guru
Rating: 86%, 204 votes
try the filter check 4.6 tool from http://www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
remove any found and restart.. this usually does the trick.
Was this helpful?
Yes
No
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
not working properly will burn all tje tracks but will not complete the process.
Answer
My 2408 increasingly often will seem to run a job and then when it gets to the apparent end it gives... (More)
Answer
The vrd-vc10 has started showing a "format error" in the display when I load dvd+r... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , OH
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
