All of a sudden one day the notebook started to run on the battery while it was plugged in. At the same time it started to smell like burning plastic, but no smoke. I shut it down as quick as I could. The next day i started it up but it was once again running on the battery, and the battery was not getting charged. Everytime I plugged it into the outlet it made that smell. I bought a Targus AC70U, thinking it was the stock power cord, but the notebook still smells with the Targus. The new Targus doesn't charge the battery either. Any solutions? I've got a Packard Bell Easynote MX45.My adaptor broke so I bought a universal adaptor, but while I was using it, the removable charger head came loose, so I plugged it in again. It started to smell like it was burning and hasnt worked since. I sit the charger or the laptop
Comments:
Mar 19, 2008
- it started to smell at first. it doesnt any more but still wont work. I still have charge in my battery.
Mar 19, 2008
Mar 19, 2008
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Comments:
Mar 24, 2008
- you mean your laptop does not work anymore?
have you tried removing your battery and work on your laptop using the external power supply? and your battery, are you charging it outside of the laptop and have tried re-inserting and use in your laptop?
Was this helpful?
Yes
No
Solution #2
posted on Jul 05, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same thing has happened to me i would really like a fix :(
compre una Hp y necesito las instrucciones en espanol,Como puedo obtener el manual en espanol?...
(More)
compre una Hp y necesito las instrucciones en espanol,Como puedo obtener el manual en espanol? Gracias el modelo esHP G60-530US(este modelo no me lo da la pregunta abajo
on my averatec 6100 i cant seem to get my linksys wireless router to connect.i have my wireless...
(More)
on my averatec 6100 i cant seem to get my linksys wireless router to connect.i have my wireless switch on but it wont pick up the signal.
