try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
If your regular charger is working in the wall, it sounds like the USB cord that you are using with your computer isn't a "charging" USB. I don't think you are having a malfunction with your BB.
Try a different charger (like your car charger instead of your home charger) - make sure while it's plugged in - the display shows that the charger is charging it, blinking - or bars going up or down, or a thunderbolt on the display screen next to the battery power symbol etc
Once you know your charger is working, its probably easiest to find someone else with a BB and ask them if you can trade them batteries for a day to see if it's a bad battery. ( You can usually buy a battery for $5 on ebay, or up to $20 in a cell phone store)
All in all, trade someone for their battery, or their charger - if you dont wanna buy one at first. See if the problem follows your old battery etc..
And if neither solve your problem then its the BB itself. I have called in to the cell company before and let them know we have a BB that will not hold a charge no matter what battery or charger I use... and they usually replace it under warranty as long as its less than 12 months old, and the white squares in the battery compartment are still white.
Remove the battery, then remove the Memory card and Sim card (if you have a sim card). Then replace battery. Try this. If this does not work, while off try connecting the device to your pc, through bb desktop software. If the device STILL does not turn on or your pc does not recognize it, you may have a hardware problem.
I was having this same issue and I was thinking it was caused from me dropping my phone. I tapped lightly around my phone after trying turning it on for several hours and now it has come back on which means there is most likely a loose connection inside somewhere. I hope this helps.
It looks battery completly drained and dead (as It took so much time), the best way first to check "Circuit" status in Battery through Voltmeter (poles)..or another way go to any cell phone shop and give a trial with another batterty to check status of your unit.
