Question about Nintendo 64 Console
Blank Screen I'm using an old T.V. for my Nintendo 64, a little older than itself. All I get it a blank black screen, when everything is connected. What do i do? P.S. The Power Light is working and on.
  • Anonymous Apr 01, 2008
    Just got this N64 system and it is likewise giving me the same problem. I have checked the RCA and antenna in plugs to make sure. I'm curious if something is loose inside the multi-out plug on the system itself. Any thoughts?
  • corthew Apr 22, 2008
    Solution for Black Screen and No Sound:
    I was having a problem with the N64 having a black screen when started up with a game in. Any game tried did the same thing. I cleaning kit and used it to clean off the terminals on the games and the game slot and it now works fine.
    Problem Solver:
  • 10 Answers
Is the connections through RCA or the old antenna in?
Posted on Mar 29, 2008
My Nintendo 64 when I was in the middle of a game it froze and the screen went all black and then it went to the tv screen saying no signal then.
Well one time I had this problem with my Nintendo 64 console when I was in the middle of playing perfect dark the screen had froze went black and then it went to saying no signal on the tv screen. The console did not over heat to cause this problem. I thought that it had died on me but I had tried a new expansion pack and it was fine after that. SOmetimes the expansion packs can blank out in the middle of a game play they can die without a warning then. Or it can say expansion pack needed or it will give the white flash that it is turning on but nothing happens after that then.
Mar 22, 2016 | Nintendo 64 Console
My 64 is not working on tv
The game cartridge contacts are probably just dirty and/or corroded. Clean em with rubbing alcohol and a q-tip. The games should work fine. Mine is the same way cause its so old. Even my Super Nintendo does it. Unfortunately, you may have to do this every time before playing, but only if they don't work the first time.
Sep 16, 2012 | Nintendo 64 Console
Blank screen when I turn on my N64
The blank screen is usually caused by a faulty connection.
If you are sure all of your cables and the expansion pack are installed correctly, try removing the pack and blowing on both the expansion bay and the expansion itself to knock any loose dust out.
If that doesn't help, check the expansion pack and then the the bay for damaged or bent pins. Check the game cart as well.
If everything appears undamaged, you may have a broken/defective expansion. See if you can get your money back and then try to find another one from a trustworthy retailer or friend.
Aug 09, 2009 | Nintendo 64 Console
Blank Screen
well, the t.v could possibly be broken, call a repair man and describe your problem and maybe they can help, but do not attempt to fix the t.v yourself as a component inside can cause fatalities.
May 29, 2009 | Nintendo 64 Console
My nintendo 64 wont read any games. I checked all of the wires and made sure everything was connected. When i put a game in, the screen goes all black and white, wavy/snowy but i could still see a little...
Check if there is dust in the game itself or the consol.Other than that it could be that you wires(I know you checked)that are hooked up to your tv may somehow be losing a signal.Or the wires in the machine(you werent specific which ones you checked) may have become frayed.Or it could just be over used and could need new prosesing software.
May 11, 2009 | Nintendo 64 Console
Bust-A-Move 2 Arcade Edition Video N64 Problem
Maybe you r cleaning it to much you should stop this and check out if the conectors that go to the tv r maybe damaged or something you should check out wats the problem.
Jan 01, 2009 | Acclaim Bust A Move 2 for Nintendo 64
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Nintendo 64 problem
Same problem with mine, i figured out that if certain parts inside the n64 are damaged or worn, it will affect the display of the game
Aug 03, 2008 | Nintendo 64 Console
Blank screen
If you're using a game cart in the bottom slot of the DS it is because you are running an older Game Boy Advanced game that does not support dual screens. Pull out all game cartrages and start the DS in it's splash/ setup screen. If one of the screens is black there then one screen is bad. It not worth fixing unless you have a warranty so at that point head to your local store and pick out a sweet new color.
May 30, 2008 | Nintendo DS Console
My Nintendo DS top screen is blank white and is not working
It's a poor connection to your top screen that's your problem, the issue is either that the conection is loose that holds the top screen ribbon cable to the board or that the ribbon cable to the top screen is damaged and will require replacing
HTH
Feb 19, 2008 | Nintendo DS Lite Console
Nintendo 64 Console Logo
220 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
