Question about Hawking Wireless-G HWR54G (603992506064) 802.11b/g Wireless Access Point
Connection to the internet.
After running reasonably well for many months my remote (wireless) laptop now very frequently won't connect to the internet when I start try to reopen a connection. If I use the Micosoft "repair" function or turn the system off and restart it usually then connects. I'm using IE 6
  • 47 Answers
If it worked for a long time then stopped, there might be a new wireless transmitter around. XP is awful at picking a connection back up once it drops. Does it drop less when the computer is closer to the transmitter? You might try changing the channel that your unit is broadcasting on.
Posted on Mar 19, 2008
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Internet connection won't register on compaq laptop
You must go into "Internet Connections" and enable your ethernet/ LAN connection. It is advised to disable the wireless connection in the interim. Thank you, Dana
Feb 15, 2010 | Computers & Internet
Mercury USB laptop connector with AT&T Service
try connecting with a cat5 cable instead of using the wireless. It is possible your problem is your wireless connection and not your service provider. Make sure your ether net connection is not disabled.
Sep 06, 2009 | Sierra Wireless Aircard 860 PC Card...
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Internet connection disappears.
You may either need to do a firmware update, or reset it back to factory default, you can download the firmware from the netgear site, or you can log onto the router and do a reset of the router.
Hope this helps,
Mar 15, 2009 | NetGear WGR614 Wireless Router
The internet connection keeps disappearing.
Change the router's IP address to ( maybe you have an IP conflict between the modem and router.
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
HP Pavillion ze2000 (can not connect to internet)
Make sure you have the internet connection you are trying to connect to is set as your defualt and the reason you are having conflicts with your IP adress is because of how ytour internet is shared.
Oct 22, 2008 | Computers & Internet
Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to and enter your service tag/laptop model # if you want).
Jun 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
THE internet is coming up internet explorer can not be connected, when it's wireless. we can plug it in and then the internet comes up.
you have to configure your wireless modem (wep/wpa) so that your laptop can connect to the internet. the reason why you cannot connect in the internet thru wireless is that the connection between the modem and the laptop has not been established. so, try to establish the connection between your laptop and the modem.
Apr 01, 2008 | Computers & Internet
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Hawking Wireless-G HWR54G (603992506064) 802.11b/g Wireless Access Point Logo
204 people viewed this question
Top Hawking Computers & Internet Experts
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
