Question about Fujitsu 24C1 Air Conditioner
Fujitsu 24c1 Air Conditioner
I WANTED TO ASK IF I COULD MOVE MY COMPRESSOR TO ANOTHER LOCATION WITHOUT LOOSING MY FREON . I ALSO WANTED TO ASK IF YOU SOLD PARTS, I'M GOING TO NEED AN ADDITIONAL 25 FEET THANK YOU , TOM
  • 236 Answers
You can pump down the unit to save all the refrigerant in the condenser.
Posted on Mar 18, 2008
Compressor won't come on I want to by pass thermostat
First check power or (high voltage) to outside unit if good make sure you have thermostat voltage or (low voltage) to the outside unit.
Feb 09, 2014 | Fujitsu 24C1 Air Conditioner
My fujitsu halycon inverter is dripping water in the house. How do I fix it?
First checking out the drainage that comes out is not blocked, and secondly need to open the air conditioner and clean the Wading and finally the third and final case to see if the machine has Freon.
Sep 20, 2011 | Fujitsu 24C1 Air Conditioner
When i on my aircon at night there is loud sound coming from the compressor
There are 2 reasons for noise.
1. Internal 2. External.
1. Internal noise, replace compressor.
2. External noise. Check comp seating bushes are not worn out/ fan blade not cracked or bend
Thanks.
Mar 09, 2011 | Fujitsu 24C1 Air Conditioner
Air conditioner isn't cooling the room
hi there,
insufficient cooling have several reason,most common factor is low freon charging due to service factor,defective thermostat control,dirty evaporator and condenser fin,try to check the current rating using ammeter clamp tester if the rated current read in tester below the rated current on tag(compressor)
you need to charge freon,if the fin and evaporator is dirty need to ve clean,if the thermostat is not functioning replace thermostat.
also consider the main defective if the aircon is running chck the compressor if it is running by touching the tip of screw driver to the top body of compressor you can feeel vibration,if compressor is not running yo don't have cooling effect only blowing of air.on repairing this this should be done by a certified aircon technician,have a nice day fix my rate,thank you very much.
May 14, 2010 | Fujitsu 24C1 Air Conditioner
Stuck with vents half open and not responding to remote control
Here is a link to the owner's manual of your Fujitsu 24C1 Air Conditioner. This will help you locate the Manual/Auto Switch on the air handler as well as offer some information on the remote and troubleshooting tips.
Let us know if this was helpful and good luck! :-)
Feb 24, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Jan 24, 2009 | Fujitsu 24C1 Air Conditioner
Unit never used--won't cool
I would call and get a couple other estimates. If it has never been used, the compressor is probably not bad.
Oct 21, 2008 | Fujitsu 24C1 Air Conditioner
No COOL Air
A short cycling compressor signals an inadequate freon level in the system.
The freon level should be checked by a HVAC professional.
You also may have a leak in your freon system, as freon does not get consumed during the cooling cycle.
Good Luck
Please respond with comments/more info.
Brian
Aug 05, 2008 | Fujitsu 24C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
77 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
