Question about Toshiba Satellite 2410-S203 Notebook
When power cable unplugs computer immediately shuts down (have replaced battery)
When the power cable detaches from the laptop, the laptop turns off (no shutdown process, just off).
I thought that this was a battery problem initially. The power cable does not have a great connection. Sometimes when plugged in there is still no power getting to the laptop. When I jiggle it a bit the power lights start to come on.
I replaced the battery and charged it up, but when I unplugged the power cable it shut down again.
Any ideas? Is there some way I can take it apart and check that the connections from the power source to the battery are working?
  • Shaggy2 Mar 18, 2008
    Thanks for your advice. Unfortunately, I find the Toshiba service centre to be prohibitively expensive for what I want. I have purchased a new battery and charged it with the same result; so it makes sense that the contacts may need some cleaning or repair.
    This is an older non critical laptop and I am happy to use it to learn more about how computers work. I am pretty set on taking it apart and seeing if I can fix it, but would like any advice on what I am going to need to do or check. If it is damaged in the process then so be it, but I would rather take a crack at fixing it myself and end up with some more knowledge about how they work.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Sounds as if the power pin (inside the computer) is damaged. The part is under $ 10 but the labor is gonna be a hundred to two hundred bucks. You can, if you are careful, fix it yourself.
You can also get a JerkStopper cable retention device to hold the cable in the correct position until you get the pin fixed. The cable retention device is designed to keep you from damaging the pin by pulling on the power cord. In this case, it sounds like it's too late for that.
Posted on Jun 04, 2008
    Novelist:
  • 104 Answers
Mmm i wouldn recommend to touch the laptop if youre not expert on that... it might be better to take it to some toshiba service and ask them to try your notebook with a new or a good working ac adapter... without the battery and with it so you will know if any of those parts are ok. Otherwise it wont be wise to keep trying by yourselve, you could damage your computer. Battery is easy to test, you just have to leave it charging over night and then try to power the computer without ac adapter... if it does not start either the battery is bad or the contacts of the battery need some clean or repair... charger is not expensive but battery does... so do not keep trying much, better go to an authorized center.
Posted on Mar 17, 2008
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
My acer laptop shows a charge {admitadly it seem slow to charge} but when I disconnect the power cable the laptop shuts down immediately, can you help. Thanks
Sounds like your battery is going bad on you. Especially if you charge it and as soon as you unplug it shuts down.If you have a volt-meter you could test it for voltage AND amperage. You may even be able to find a local store that might be willing to test it for you.
Mar 19, 2011 | Computers & Internet
Battery is showing 100 percent but you unplug power supply computer shut down also when you wiggle cord power shuts down
The DC jack in the computer has detached itself from the motherboard causing intermittent shutdowns, the laptop must be dis-assembled to re-solder the jack back in place, and may need to replace the DC jack if the old one is not suitable.
Feb 08, 2011 | Toshiba Satellite A105 Notebook
I attempted to shut the computer down via the startup menu but closed the laptop prior to it shutting down. When I reopened and turned on it asked for password to log into windows but the hour glass...
Try pressing and holding the power button until the computer shuts down.
Also note that when removing the battery, you also need to unplug the power cord in order to shut down the computer in that manner.
Dec 29, 2010 | Computers & Internet
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Nov 19, 2010 | Computers & Internet
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
It started with the computer not getting power weeks ago but you could play the cord it would kick on no big deal. I figured I needed a new cord. Then yesterday it started turning itself off. If it sat...
Your power jack is bad. The cable and DC jack are a one piece cable that can be unplugged from the motherboard and replaced. They are available on EBay for around 30 bucks or less and takes approx. 30 minutes to change out.
Jun 27, 2010 | HP Pavilion dv7-1132nr Notebook PC
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
Hi
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite 2410-S203 Notebook Logo
424 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
