A plastic piece fell out of my cannon pixma
My printer is not working.
    Guru:
  • 377 Answers
Hi
just try to using a pinst to take the plastic
or open the cover of your pinter
to fix that
thx
cropp
Posted on Mar 19, 2008
Paper jam in output tray is displayed but i cannot solve
When it says that it usually means there is a paper scrap in the sensor flag that is under the long gray roller. It is a black plastic tab toward the right side behind the white plastic guides that the paper comes out under. You need a flashlight to see it and you need to be careful not to break the tab.
Apr 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon MP600-where do you see Error Code? I just get "Paper output slot" paper is jammed; but it's not!
That error usually comes from the sensor under the platen roller. It's a tiny black plastic piece that the paper pushes when it passes under the platen roller. The end can bend when you pull out a jam, or a tiny paper scrap can hold it down. The same screen gives error codes when there are other malfunctions, the error now is just that sensor.
Dec 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The paper will not feed on the left side
Every time I see these I find pens, candy, clips, other objects have fallen down the back where the paper goes. One lady picked up her printer, turned it upside down and shook it and a bic pen fell out, It worked fine after that.
Nov 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
What is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
Apr 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a canon pixma mp180. some little plastic pieces fell into the paper feed. I pulled what i could see out but now the paper jams when being fed. I did the maintenance roller cleaning. I was wondering...
I kept running the maintenance roller cleaning with paper in the feed and eventually I was able to see the tip of the plastic piece that had fallen in as I pulled the paper through with my fingers, I was able to get the whole piece and now the printer is golden.
Jan 28, 2009 | Office Equipment & Supplies
Printer fell...extra part?
hmm..well..that may not be your only issue..if the printer fell to the floor.
Oct 13, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Mechanism, belt came off.
Turn your machine upside down and give it a shake. Most likely, a small spring will fell out. The same thing happened to us and sure enough, it was the spring. This spring will give the tension you need to hold the belt on the plastic piece.
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon pixma mp130 5100 service error
Hi You can Try 2 things.
Hope you try it may work
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
44 people viewed this question
jasbo
jasbo
