Try taking it apart and letting it all sit straight up for one week thats what i did it works sometimes if not your best set is to find a local cell phone shop not a franchise one like in a mall and ask if they can get it fixed or refurbished..
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone. Razr V3 external battery charger
seems some components inside your phone has shorted out. overnight charging is not recommended for it could cause overheating of the components of your phone which in time develops shorts.shorts , of course consumes rapidly the charge of the battery and it damages the battery also. have your phone diagnosed and fixed. next time if possible, remove the phone from the charger when it fully charged.
