Question about Toshiba TP55H95 55" Rear Projection Television
Toshiba TP55H95 Shutting Off
I have the exact same problem as was described by pompomooset (Jan 17,2208) with my Toshiba TV (It shuts off and the power light flashes). You recommended ordering the $11 troubleshooting manual. Should I instead put that money toward a new power supply, or could there be other componants causing the problem? I asked pompomooset if he had any success, but he has not replied yet. Thanks
  • 2 more comments
  • mikjbak Mar 18, 2008
    Thanks Guru;
    That helps me understand the issue. I will order the manual and go to work. Hopefully I can figure it out!
    Best regards,
    mikjbak
  • Anonymous Apr 15, 2008
    I have the same problem. Did you get yours fixed? If so, what was the problem and how did you fix it?
  • Giles381 Jun 01, 2008
    I have the same problem with the tv. I can't get it back on. Did you order the manual? Did it help?
  • Anonymous Aug 15, 2008
    We just got this tv from a friend he told us the problem. we thought that it was just the light bulb. but we figured that it wasnt. and i will loose picture after 5 minutes. no it wont turn on. you can hear it try to but it doesnt. and also the power light will just flash.
  • Toshiba Master
  • 8,617 Answers
The power supply board may not be the problem as that only provides the voltages that go to the other areas of the chassis. Where as a manual will explain where the voltages go and what has to happen for the set to start. the power supply could be good but a leaky diode on say the signal board could allow voltages to increase thereby shutting the set down. Unless youre really good at troubleshooting, I would highly recomend getting a manual.
Posted on Mar 17, 2008
  • Sonny Berry
    Sonny Berry Mar 18, 2008
    good luck if you need any assistance let me know.
It get no power when i plug it up
If toshiba tp55h95 either google the model number for this or ask me based on what is wrong
Mar 20, 2012 | Toshiba TP55H95 55" Rear Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Where can I find a High voltage tripler for this Toshiba TP55H95
Sears Parts Direct claims to have one part number is 24082877
Oct 16, 2009 | Toshiba TP55H95 55" Rear Projection...
Have a toshiba model # tp55h95 tv. The power light is blinking
Something is keeping your power supply from starting up. Bad capacitor...most likely. Replac 'em all! They're cheap!
May 21, 2009 | Toshiba 50H81 50" Rear Projection...
Convergence
About 35.00 - 70.00 to do it yourself depending on parts.
Apr 20, 2009 | Toshiba TP55H95 55" Rear Projection...
Turn of sometime
I would check out your power supply and shut down circuitry as thats what yourset is doing when it shuts down its ging into the protection shut down. You can get the power supply and shutdown troubleshooting quide for your set at the following link for 10.99 and if you request that they email it they will. You just have to return after you order and click on the contact link to request they email instead of mail your manual. Heres the link.
http://servicemanuals.vstore.ca/
Jan 05, 2008 | Toshiba TP55H95 55" Rear Projection...
Red light bflashing
Sometimes a power surge will cause a projection back TV to shut down and flash like that. If you unplug it from the wall and let it sit for a minute and then plug it back in, it should reset itself. If that doesn't work it will probably have to be serviced. If it does work, make sure you get a nice surge protector so you don't fry your TV.
Dec 28, 2007 | Toshiba TP55H95 55" Rear Projection...
Toshiba TP55H95 55" Rear Projection Television Logo
305 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
