Question about Polaroid a520M Digital Camera
How could I get another one?
My camera just stop working and it don't want to come on no more and I tried to put new batteries in it and it still didn't work
    New Friend:
  • 136 Answers
You can return it to the place where you purchased it
Posted on Mar 17, 2008
Hp photosmart camera stopped working
It sounds like a dew problem. Has it been left for a while without use?
Leave it turned on in a warm room for a few hours and it should start working again. Hope this helps.
May 10, 2012 | HP Photosmart 435 Digital Camera
After putting battries it's not getting on.batteries are checked and found serviceable.
The problem could still be within the batteries, digital cameras are very demanding. For example, if an alkaline battery stops working in a camera, very often the battery is still plenty good, and will work fine in other devices such as a flashlight. So before you give up on it try a brand new quality battery, I like the modern rechargables.
Nov 05, 2011 | Canon PowerShot A550 Digital Camera
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
EOS Rebel G 35mm SLR Camera: auto focus has stopped working...
It could be either of two things.
1. AF motor in lens died. Try a different lens and see if it works.
2. AF module in camera dead. This requires repair shop to install a new module.
Before you do either of the above, put in new batteries and check the setting of the AF/ MF switch on the lens itself.
May 03, 2010 | Photography
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Does not turn on, bought new battery, still not charging.
I found out that the battery was put in upside down! I was not sure if this was the case because I was able to close the camera. I tried turning it around but it would not fit. I did not try to put in upside down. I think my grandson took it out by mistake and he put it back wrpng.
Unfortunately, there is no safeguard or guide, to stop one from inserting the battery incorrectly!
Apr 08, 2009 | Kodak Easyshare M753 Slim Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Polaroid a520M Digital Camera Logo
32 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
