Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xp professional installation on hp pavilion dv6700 cto notebook
Hi
i got a hp pavilion dv6700 cto notebook with vista and i would like to downgrade to xp professional sp2 but i could not do that because of sata drivers. i am able to install windows server 2003 sp1 with F6 method but not with xp. i will be very thankful if i get assistance.
  • 12 more comments
  • dav01 May 14, 2008
    i can not install window xp sp 2
  • Anonymous May 18, 2008
    now at that time i have windows vista, but that operating system is not recommended in my collage. I want Only windows xp service pack 2 install in my notebook. my notebook serial name is hp pavilion dv6700.
    give me the solution.
  • vimper_here Jul 07, 2008
    thanks,.....
  • anvarc Sep 06, 2008
    Yes I also have the same problem with my hp pavillion dv6700. when I tried to install xp, it is showing no hard driver detected. Give me a solution for installing xp
  • Anonymous Oct 22, 2008
    hmm... there must be easyer way!!!
  • Anonymous Oct 23, 2008
    m havin HP dv6700 with vista n i want to downgrade it to xp but i cudnt. i dont have original windows xp but i do have nlite application. what should i do
  • EGLA Oct 31, 2008
    BIOS versin F.58 : "Factory installed OS........Vista"
    I want to downgrade it to xp but I cudnt. :-((
  • Eyad-nouider Nov 15, 2008
    same
  • smkr2k5 Nov 20, 2008
    harddisk error message when i installed xp i pravilion dv6700 notebook, how ca i solve this pbm
  • yathishs Nov 29, 2008
    Hi I too face the same problem while installing Windows XP Proffessional with SP2. While installing it ask fro SATA driver. please suggest the link to download file.
  • rharinath Jan 06, 2009
    Hai
    i have HP dv6600 laptop, in sytem configuration i dont have a select SATA Native Mode, what i to do....
    pls help tme to install winxp in to my laptop
    please reply to
    rharinath@hotmail.com
  • bhathiyaj Feb 06, 2009
    i have a HP Pavilion dv6700 CTO Entertainment Notebook PC i want to setup WinXP. bt cant. plece help me...
  • Anonymous Mar 03, 2009
    i didnt solve it for now i will try to fix it
  • sathishku418 Apr 07, 2009
    Hi i have same Pblm did you find the sloution for this pblm if u .. please tell me !!
  • 3 Answers
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Posted on Mar 18, 2008
Download and install Black XP. It worked for me.
Posted on Mar 25, 2009
SHAFIHOT HAVE ONE SOLUTION
USE SATA ENABLED XP PRO CD
AND SOLVE THIS PROBLM
AVAILABLE SATA ENABLED XP
ISO IMAGE
email me: shafihot@yahoo.com
pub_ftp@linuxmail.org
pub_ftp@rediffmail.com
charges: IN BAHRAIN 10 BD,,,,,,,,,,,, INDIAN RS: 1000 RUPEES
24 HOUR TECHNICAL SUPPORT
Posted on Oct 17, 2008
Guys,
A lot of things to read, a lot of things to understand. Becasue if this, there will now a confussion between his answer & them. Well to be honest, the root of the issue regarding VISTA to XP on Laptop machine is the BIOS. I believe the BIOS of HP Pavilion is 'PHOENIX' (i hope my spelling is correct). My assumption is, HP & the manufacturer of BIOS has an aggreement to KILL Windows XP OS. They remove the OPTION in the BIOS to change the setting of SATA. My advice to all users of LAPTOP, it is better to buy IBM Thinkpad rather than HP. IBM is using different BIOS manufacturer, & it is possible to disable SATA drive.
NOW, on my solution to solve your issue. Kindly download a device driver of SATA & then extract the file to floppy disk. Then make an ISO image of windows XP SP2. Make sure that you have a knowledge to incorporate SATA device driver in your ISO image before burning it into CD. Because if not, you may need to press F6 while WinXP is loading device driver during installation. Once done & created a WinXP bootable disk, you may install WINXP without any issue of SATA device.
Thanks,
Arnel B. Gomez
Posted on Feb 14, 2009
SHAFIHOT SATA enable SOLUTION
solution of sata enabling hdd problem
first check ur bios status
sata is enabled, in the popup menu select sata native mode enable
done , now run your normal xp cd and access hdd drivers
note: bios entering key F2
Technical support mail me
shafihot@yahoo.com
shagar.boss@gmail.com
Posted on Nov 02, 2008
My laptop hp paviliion dv6700 is not boot[ bios screen not appear and ture off after 20 second ] after installing xp from this busted nlite software give me solution please
Posted on Oct 01, 2012
I got a hp pavilion dv6000 comes with vista but i need to format and want to install xp, but not possible due to sata driver not found even in net and cd,
kindly help me in this subject, i will be appriciate for your keen disposal
thanking you for your benign consideration
mubarak from saudi arabia
Posted on Dec 02, 2008
I have the same model. I nlite and generate Win2k3 server CD. It works fine during installation no issue.
But when i tries same patron with XP, its starts giving me files missing error while copying setup file.
I have tried multiple cd but same file missing error.
Any idea.
Posted on Nov 11, 2008
I wnan rigister ker for win xp sp2
Posted on Nov 04, 2008
Try the link http://www.microsoft.com/WindowsXPProfessionalWithSP2
For find best solution.
Please Rate me if this information helpful for u.
Posted on Oct 24, 2008
Dear Sir,
i have the same problem and i can't install win-xp sp2 in my notebook HP dv6700, appretiate if i get help.
many thanks
Zaid
Posted on Oct 23, 2008
Description This document describes installing Microsoft Windows 2000 or Microsoft Windows XP using native Serial ATA (SATA) drivers. Solution Incorporate the SATA driver into the Windows installation as follows:
Stand Alone Windows Installation
  1. Download the latest SATA AHCI driver from www.hp.com . For addition information, HP Notebook PCs - Locating HP Software, Driver and BIOS Updates
  2. Download and install an orthodox file manager. NOTE: For this example, Total Commander is used. Refer to the software help files for additional assistance.
  3. Download and install the CD and DVD data recovery software. NOTE: For this example, Ultra ISO is used. Refer to the software help files for additional assistance.
Extracting files
  1. Start Total Commander by clicking Start , All Programs , Total Commander and then click Total Commander 32 . If the non-registered version is used, follow the pop-up windows instructions. NOTE: For assistance and instructions on using Total Commander, view the Total Commander help file.
  2. Locate the downloaded SATA AHCI driver using the directory structure in Total Commander. Select the SATA AHCI driver. Figure 1: SATA AHCI driver located xp professional installation on hp pavilion dv6700 - c00763284.jpg
  3. On the File Menu, click File and select Unpack Specific Files .
  4. Type the target location to unpack the file. Figure 2: Enter unpack location c00763285.jpg
  5. Locate the unpacked files.
  6. Repeat the unpack process for F6flpy32.exe .
  7. Open the temp.IMA extracted from the F6flpy32.exe file using Ultra ISO or equivalent application. xp professional installation on hp pavilion dv6700 - c00763286.jpg3: temp.IMA driver files c00763286.jpg
  8. Copy the temp.IMA driver files to a floppy disk or burn the files to a CDROM.
Disable SATA native mode
  1. Start the notebook PC.
  2. Repeatedly press the F10 key (or key designated by the notebook PC) until the notebook enters the Computer Setup screen.
  3. Use the arrow keys to select System Configuration .
  4. Use the arrow keys to select SATA Natixp professional installation on hp pavilion dv6700 - c00763287.jpgnd set the mode to Disable . Figure 4: Disable SATA Native Mode c00763287.jpg
  5. Press the F10 key (or designated key to accept the changes).
  6. Save changes and exit Computer Setup.
  7. The notebook should restart.
Installing Windows using native SATA drivers To install Windows XP with native SATA driver, perform the following steps:
  1. Boot the notebook PC.
  2. Insert the Windows XP installatixp professional installation on hp pavilion dv6700 - c00763288.jpge optical CD/DVD drive.
  3. Press the F6 key when prompted Figure 5: Third Party Driver Prompt c00763288.jpg
  4. Press the S key to specify the additional devixp professional installation on hp pavilion dv6700 - c00763290.jpggure 6: Specify Additional Device c00763289.jpg
  5. Insert the SATA driver disk into drive A. Figure 7: Insert Driver Disk c00763290.jpg
  6. Follow the on-screen prompts.
Enable SATA native mode
  1. During the starting of the notebook PC, repeatedly press the F10 key (or key designated byxp professional installation on hp pavilion dv6700 - c00763291.jpg PC) until the notebook enters the Computer Setup screen.
  2. Use the arrow keys to select System Configuration .
  3. Use the arrow keys to select SATA Native Mode and set the mode to Disable . Figure 8: Enable SATA native mode c00763291.jpg
  4. Press the F10 key (or designated key to accept the changes).
  5. Save changes and exit Computer Setup.
  6. The notebook should restart.
Posted on Oct 16, 2008
Hi i got a hp pavilion dv6700 cto notebook with vista and i would like to downgrade to xp professional sp2 but i could not do that because of sata drivers. i am able to install windows server 2003 sp1 with F6 method but not with xp. i will be very thankful if i get assistance
Posted on Oct 13, 2008
Pls go through this very useful link i had found about a month back,
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
complete step by step nlite procedure for slipstreaming sata drivers into xp cd versions prior to vista for installation on laptops etc. i hope this information is beneficial to the reader/user.
abhay r somkuwar.
Posted on Aug 31, 2008
Uyuh
Posted on Aug 26, 2008
But what about drivers for this type of laptop for win xp?
Posted on Aug 22, 2008
Asif Ahmed Khan
Senior Software Engineer
Palmchip Pvt. Ltd. Lahore Pakistan
Extracting files
  • Asif Khan
    Asif Khan Oct 16, 2008
    Description
    Solution
      NOTE:
      NOTE:
    Extracting files
      NOTE:
      Figure 3: temp.IMA driver files
    4. Use the arrow keys to select SATA Native Mode and set the mode to Disable .
    2. Insert the Windows XP installation CD into the optical CD/DVD drive.
    4. Press the S key to specify the additional device.
      Figure 6: Specify Additional Device
    1. During the starting of the notebook PC, repeatedly press the F10 key (or key designated by the notebook PC) until the notebook enters the Computer Setup screen.
4 Suggested Answers
Trust Me
  • 26 Answers
SOURCE: installing windows xp on hp pavilion dv 6516 tx
I'm not sure solution #1 is very explanatory, so....
IF you want to install XP on your computer, Windows XP will load most of the drivers you need automatically.
For the drivers that are specific to your HP pavilion
you will be able to download device drivers from HP website
or, request a driver CD
When XP is installed [assuming you or someone can do that]
you can:
Go to the 'My Computer' icon [right-click]
Choose:
  • 'Properties'
  • Then Choose 'Hardware'
  • Finally, choose 'Device Manager'
Here you will have a list of all your hardware
If you have any drivers that need to be installed, there should be
a yellow (?) question mark by the name of the hardware
Most devices/hardware will be handled by XP SP2
The default drivers will be loaded automatically
For example, your keyboard:
Above you see the window that opens if I double-click on
the 'Keyboard' icon.
For XP to function, you only have to worry about the ones
with the yellow (?) question mark
Or, if you want to add a specific driver, like a Video or Sound driver, but you don't see a yellow (?) question mark
you can still install/update the driver at the 'driver' tab
[second tab in the picture above]
If you need more specific help I can do that too
Posted on Feb 20, 2008
SOURCE: XP Drivers for HP Pavilion DV 6516 tx Laptop
I too had a similar problem. I got VMware (virtual machine)installed and XP installed inside that.
Posted on Apr 02, 2008
SOURCE: server 2003 sp1 not installing
Plz be posted , in case of server installation - it is veryu delicate the above situation may occur only for the following points .
1.intallation files were skipped by user manually (due to bad CD)
2.Improper Installation (in case root directory contained XP os and installation was overridden windows folder )
3.using a crack patch to OS for CD-KEY.
check and let us know.
Regards,
Sushil
Posted on May 28, 2008
Hi I have a hp pavilion dv6700, when I press the
Go to this link: www.hp.com
  1. click on support & drivers
  2. enter a product name/number which is: Hp Pavilion dv6700, then click go
  3. click on HP Pavilion dv6700 CTO Notebook PC
  4. select your operating system, and click next
  5. click on the + sign by keyboard, mouse and device input then click on HP Quick Launch Buttons and download it
  6. after it downloads open it up and follow directions to finish install
Nov 16, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Os problem
hi..yea but download 1st all drivers support for what kind OS/Windows are your using..good luck and have a nice day
Jun 25, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
How to downgrade vista to winxp pro at Hp pavilion DV4-1204TU ?
Well, this may make you think twice:
I bought a presario from circuit city last year, and I paid $200 to downgrade to XP. Everything was fine until it crashed last week. IT went completely bizzerk. HP won't provide support, cause I changed it. Circuit City is out of business, not much help there.
Basically, I am completely #$%%@@.
I am now paying to get Vista put back in. :-(
Jun 09, 2009 | HP Computers & Internet
Drivers
What drivers do you need? If all drivers, try this link to download a software to do this for you:
http://www.laptops-drivers.com/hp-laptop/pavilion-dv6700-xp-hp-software-update.html
Mar 24, 2009 | HP Pavilion DV6700T Notebook
My Hp pavilion tx2000 cant play audio files,cant connect to net
Hi James
First, Sound drivers:
HP Pavilion tx2000 CTO Notebook Realtek High-Definition Audio Driver 6.0.1.5494 A from HP notebook
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38206.exe
and video drivers..
HP Pavilion tx2000z CTO Notebook NVIDIA GeForce Go 6150 Video Driver 7.15.11.5682 A
http://notebook.free-driver-download.com/url.php?id=TlRJeE5Eaz0&link=0
Now network:
HP Pavilion tx2000 CTO Notebook NVIDIA nForce Chipset/Network Driver 5.53 A
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38205.exe
and wireless!
This is an older WIFI driver that only works in XP, and in certain HP Pavilions, but try it.
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36684.exe
and this is the Vista one that is correct for your laptop, it probably doesn't work in XP but if all else fails, you could try it. (You should really run Vista on it, I reckon)-----------------
HP Pavilion tx2000 CTO Notebook Broadcom Wireless LAN Driver 7.0 Windows Vista
http://notebook.free-driver-download.com/url.php?id=TlRJeE5EWT0&link=0
All support you need is here at HP Tech Support:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3650975
Good Luck
Merry Christmas
Chris (ziraffa)
Dec 23, 2008 | HP Sound Card
My hp pavilion dv6700 audio donot work i change from vista to XP
Reinstall the drivers for XP. This should fix the problems.
Dec 21, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv2214US ethernet
Go to www.hp.com WEB site, then to their support/download page
Search for the network driver for you model laptop. Download and install the network driver.
Nov 28, 2008 | HP Pavilion dv2214us Notebook
How can i get my sata controller drivers?
This should be aviable on the CD that came with the system, Check your manufactures page to see if they have a downgrade cd aviable since most companies now offer this. In case there is then you can download the drivers from the manufactures web page and put it on a floppy so you can use it .. (win XP will tell you to press F6 to install 3rd party drivers. You may also try www.driverguide.com or you can use certin software like driver magician to find and download them for you..
Jul 08, 2008 | Microsoft Windows XP Professional With...
Win Vista and Win XP Probs?
which applications are not compatible? Do you try to run them in compatibility mode set at windows XP?
You may install VMWare Server to run a virtual machine XP from Vista without dual boot, allowing running XP and Vista at the same time, its easy to install/configure, need a good computer with 2Gb ram min.
Jul 04, 2008 | Microsoft Windows XP Professional With...
Where do I get the Downgrade to XP Pro
generally manufacture dont support downgrade, before downgrading please check for drivers for xp in manufacture website
Jun 24, 2008 | HP Pavilion dv6000z Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
15,215 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
