Question about Hitachi CP-X385 Multimedia Projector
How to clean air filter in HITACHI CP-X385 - Hitachi CP-X385 Multimedia Projector
    New Friend:
On the right side of the projector there are vents, put a vacume cleaner up to the vents, and the filter will be cleaned.
then on the top of the projector click the down arrow, then go down to option, use the down arrow to highlight the filter time, then hold the reset button on top of the projector for about three seconds. Clean the air filter every 100 hours.
Posted on Jul 30, 2010
SOURCE:
How do I clean the filter of the Hitachi CP-X1200 multimedia Projector ?
Remove and use fine bristle brushes assisted with a jet of air which will clean up the fine netting of the filter. It is important that the filters are occassionally cleaned so that there is no dirt accumulation within the lens unit that can reduce the life of the LAMP and save an expensive repair.
Aug 19, 2011 | Hitachi CP-X1200 Multimedia Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Projector problem
It's probably the video cable from the PC. Treat your cables carefully. Don't bend them sharply when stowing.
Oct 02, 2009 | Hitachi CP-X385 Multimedia Projector
Price of Hitachi CP-X385 Multimedia Projector ?
I came up with a price range of $250.00USD to $370.00USD through various searches.
Apr 17, 2009 | Hitachi CP-X385 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Mar 23, 2008 | Office Equipment & Supplies
Hi there
Look at the bottom of the Projector , you'll see a thin grey line with two edges on it. That is the filter. Grip on the sides and gently pull it out.
Mar 17, 2008 | Hitachi CP-X385W Multimedia Projector
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Hitachi CP-X385 Multimedia Projector Logo
660 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
