Question about Dell Dimension 8200 PC Desktop
Cage fan always on
Hi !
I have a DELL Dimension 9150 and since Dec 07 the cage fan is always ON. It used to be that the fan turn on after the PC was running for long periods of time. I've cleaned the area but no result. There is a direct 12v connection to the motherboard, and I don't know what else there is that controls it? Should I do a system restore in Win XP? Any help? Paul.
  • Paulvman Mar 17, 2008
    From your experience, do fans act up this way? In any case, I'll re-open the case, get the part number and order a new one. Thanks, Paul.
  • 52 Answers
Replace the fan
Posted on Mar 17, 2008
Good video, no sound with my dell dimension 9150
You can try to get the drivers off of your CD or you can download the drivers from here:
http://www.dell.com/support/drivers/us/en/19
1. Just choose "Select A Different Product"
2. Then choose "No, Choose from a list of all Dell products" and
select "continue"
3. Then select "Desktops"
4. Then select "Dimension"
5. Then select "Dimension 9150/XPS 400"
6. Now just scroll down and pick the drivers you need.
Don't forget to install your chipset and network drivers as well.
Jun 04, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a Dell dimension 9150 with 2 hard drives. The PC wont start up so I want to copy the data on the drives using USB 2.0 To SATA IDE Cable but when it reads the drive Windows says it can not read the...
It sounds like your dimension 9150 desktop has a primary and secondary drive.now when you say it wont start up what are you referring too?does it not power on at all, do any of the fans or lights come on. and also sounds like you got an external hard drive. now I got confused when you explained when it reads the drive windows says it cant read the drive. My question is I thought the pc would not start up? can you explain little more in detail, so i can try and give you the right advice?
May 26, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I want to restore my dell dimension 9150 to factory settings can u help
If you were using Windows Xp just press Ctrl + F11 when you turn on your computer.
Press F8 if you were using Windows Vista then select repair your computer from the list.
Then if you have any disk or any Operating System disk insert the disk then boot from CD and follow the on screen instructions.
Hope it helps you....:)
Sep 06, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
The card cage fan is always running very fast as soon as computer is switched on ,what to do
Either ignore it and let it cool your system on a higher speed, or replace your fan. If that doesn't work, your motherboard may be damaged.
Hope this helps.
Feb 23, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
DEll E310 fan make strange noises at various times. How can I replace the fan?
You didn't state which version you have, Slimline, Mid-Tower, or Desktop.
I'll give you the link to the Dell Dimension E310 Service Manual, and we'll go from there,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
FIRST:
Computer off, unplug the power cord from the surge protector, FIRST, then unplug the power cord from the back of the power supply. (Back of computer)
Unplug all cables connected to the computer. If you are not 100 percent sure where they plug into, now is the time to make yourself a chart, and add notes.
Work on a table, open the computer case.
(Cover Release Latch button on the rear of the computer, top side. The Right side cover opens.
Tilt it out, lift it up to remove. Or on the Service Manual main page, scroll down to Removing the Computer Cover, and left-click on it)
With the computer cover open TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Static can fry out your computer's hardware components, and you probably won't see it, or feel it)
1) The Floppy Disk cable has to be partially removed.
2) The Processor's Heatsink Assembly has to be removed.
3) The SATA harddrive cables, need to be slipped out of the top of the Fan assembly cage's, squeeze connectors.
(This will make more sense, once you view the SATA harddrive's cables, and where they go across the Fan Assembly)
4) Then you can access the Fan Assembly, to get to the Fan.
A) With this Dell Dimension model, you have to remove the Floppy Disk flat ribbon cable, to access the Heatsink assembly, that sits on top of the Processor.
Remove it from the Floppy Drive ONLY. (Not shouting) Leave the cable connected to the motherboard.
You also have to slip the Floppy Disk's flat ribbon cable, out of the connector tang, that is on top of the Processor's Heatsink assembly.
(Flat steel tang, that is part of the Heatsink Assembly's frame, or cage. Pull up on the side that faces the rear of the computer, slip the Floppy Drive cable out)
This information is more easily seen, if you view the illustrations for - Removing a Floppy Drive.
On the main page of the Service Manual, scroll down to Removing and Installing Parts, and left-click on it.
On this page scroll down the left column, and left-click on - Floppy Drive
B) Removing the Processor Heatsink Assembly:
The Processor Heatsink Assembly is essentially a U shaped metal cage, that has a Heatsink attached to it.
There are 2 screws that hold the front of this metal cage down, and when removed, the cage itself tilts towards the Back of the computer.
(You may have to remove the Power Supply, to access the top screw of the Heatsink cage, or use an Offset screwdriver)
The tangs are triangular shaped, and are on the bottom of the metal cage, towards the Front of the metal cage.
The metal rectangular cage tilts back on two pivot pins, then it can be lifted up, and off.
In Removing and Installing Parts, left-click on Removing the Processor, for illustrations. (Or scroll down the page to this heading)
C) Removing the SATA harddrive cables, out of the connectors on top of the Fan Assembly:
This can be more readily seen by clicking on -
Installing a Harddrive, in Replacing and Installing Parts.
D) Now you can access the Fan.
The Fan is inside a shroud. The shroud is held to the Fan Assembly cage by plastic tangs, that are part of the shroud.
The tangs go through slots on the plastic Fan Assembly's cage.
The tangs are squeezed in, so that the hook end of the tang is able to slide out of the slot.
(It may be that the tang is pried towards the outside, so that it will clear the slot)
It's a lot of fun(?) trying to keep to tangs squeezed, so that you can slip one side of the Fan shroud, out of the slots.
This should release tension so that the other side's tangs will be able to slip their corresponding slots.
Buying a replacement fan will require a little homework, and searching various websites that offer a compatible sized fan. (Or peruse your local Mom and Pop computer repair shops)
You need to know the diameter of the Fan, as well as the thickness, (Or depth), of the shroud that surrounds the fan.
Also what type of connector it uses. 2 pin, 3 pin, or 4 pin.
The size of a fan, and the thickness of a Fan shroud, are usually stated in Millimeters. If you use the Inch system, go online, and use a free Millimeter to Inch Converter.
Here is one example, of a website that offers computer case fans,
http://www.directron.com/casefans.html
BEFORE you reinstall that Processor Heatsink Assembly! (Not shouting)
You MUST clean the top of the Processor's case, and the bottom of the Heatsink that sits on the Processor.
You will either see Thermal Paste, or a Thermal Pad.
If it is a Thermal pad, remove it, throw it away.
They are Junk, and cannot be reused!
I use an old credit card to scrape the top of the Processor's case, and the bottom of the Heatsink.
Stiff plastic, and is anti-Static.
I use Isopropyl Alcohol with Q-tips to clean the remaining thermal paste residue off.
(Rubbing Alcohol. 91 percent alcohol, or better is best)
Usually takes quite a few Q-tips, dipped in alcohol to do this.
Both surfaces must be CLEAN!
CAUTION!
Isopropyl Alcohol is EXTREMELY FLAMMABLE, and burns clean. The flame is virtually colorless. Use in a well ventilated environment, and with no sparks, or flames present.
The top of a Processor's case, and the bottom of a Heatsink are not perfectly smooth. To the human eye they may seem so.
There are microscopic pits, and valleys. These create Air Pockets.
Air is an Insulator, not a Conductor.
Thermal paste fills these voids. Thermal paste is an excellent Conductor, and transfers heat well.
The heat Must be transferred from the Processor to the Heatsink, so that the fan will transfer the heat away, from the fins of the Heatsink.
When a Processor becomes too hot, it turns off. (BIOS turns it off)
This is a Fail Safe feature that is built-in, to keep the processor from burning up.
Jan 31, 2010 | Dell Dimension E310 PC Desktop
Operating system OEM software disk needed.
Go on Ebay and purchase a Windows XP OS Disk with OEM number there. Make sure its Original and not someone's copy. I use WIndows XP Professional myself.
Oct 21, 2009 | Dell Dim.9150 Pentium D 820 Dual...
Hello at start up of my dell 9150 i have this message "card cage fan failure" so i press F1 and the computer work but do i have a solution to not having this message again?
Yes, you need to replace that fan and not run your computer without it working because it can cause it to overheat and then you'll have to replace a lot more than just a fan. Open up the side of your computer and see which fan is not moving when the computer is turned on but it will be the one attached to the card cage :c)
Jun 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
How do I remove the cover from the Dell Dimension 4100?
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgRemoving and Replacing Parts: Dell Dimension 4100 System Reference
This link to Dell's support site should help you figure out how to open the case whether it is a tower or desktop. This article comes with images and will show you everything from the assembly/disassembly of the cover, front panel, drive cage, motherboard, CPU, etc.
Hope it comes in handy and don't forget to bookmark the page!
Mar 27, 2009 | Dell Dimension 4400 PC Desktop
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
206 people viewed this question
Alun Cox
