Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi 55vf820 problem
The tv will not respond to any functions other than on/off, volume control, pip, and last channel from the remote. the only sidepanel button that functions is power. It is stuck on last channel viewed. No response with remote or buttons on TV. please help
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
Posted on Mar 20, 2008
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Pip won't turn off
how did you explain the problem you have to reach the correct code
from remote to turn off or on of the pip circuit - i can suggest to
use the original remote control or somethig else delfo
Mar 21, 2008 | Panasonic CT-32G22 32" TV
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
Problem with PIP Function
To turn off PIP. Use tv menu and auto set channels, once searching for channels, turn off and PIP will be gone. If you can't access auto program tune tv to channel 3 and try again.
Nov 24, 2007 | Sony KP-53V75 53" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
308 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
