Question about RCA P52926 52" Rear Projection Television
Projection mirror should the mirror be screwed all the way down
  • 149 Answers
What is wrong with your TV
Posted on Apr 04, 2008
Can we seperate the tv from the speaker to transposrt it up stairs?
You should be able to take the screen off and the top black plastic shroud that holds the mirror off to transport it.
1) To do this, you will pull the speaker grill cover off on the front bottom.
2) I think there are four screws at the bottom of the screen holding the bottom in place. Use a 1/4" socket.
3) Disconnect the wire harness going to the screen by squeezing the tab on the connector - very easy to do.
4) Remove all the screws on the black plastic shroud - about 8 of them. Have someone hold your screen and gently lift the screen off. The black shroud I think still has some screws holding it in place that become visible once you lift the screen off.
5) Once the screen is off, there should be a set of screws that are holding the shroud down. Remove those and gently put the shroud on the floor where the mirror cannot get damaged.
6) Installation is reverse of the above.
Note: This would be a good time to clean the mirror and tops of the CRT bulbs. It will make your picture much nicer if it hasn't been done. Use a non streaking glass cleaner on the mirror and bulbs. For the screen, just wipe it down, don't spray it with glass cleaner.
Feb 26, 2011 | Toshiba 42H83 42" Rear Projection...
How do i clean mirror on a sony KP-57ws520
Fairly easy to do.
Follow these steps:
1) Unplug the TV
2) Remove the lower access panel (the pressboard with all the holes in it) by removing the screws holding it in place. (This is the panel where where your connections are made)
3) Remove all the screws on the big black shroud on the back that actually holds to mirror. There are probably about 15 screws.
4) gently lift the panel off and set in on the floor or table where you can clean the mirror. (remember the mirror is attached to the back side of it) I usually put in on the floor.
5) clean the mirror with glass cleaner or non-streaking solution.
Reverse the steps above to re-assemble.
Feb 18, 2011 | Sony KP-57WS500 57" Rear Projection...
MIRROR HOW TO REPLACE
maryannefede,
The mirror in your unit is attached to the inside rear of the projector. If you remove all the screws around the perimeter of the top rear of the unit you should be able to remove the back and see the mirror. The mirror is held in with screws around the perimeter. Cost is about $100.00 US at http://www.encompass.com .
Thanks for using FixYa and for the great rating.
hardrocko
Nov 30, 2010 | Sony KP-61XBR48 61" Rear Projection...
I have a spider inside the screen and need to know if I can somehow take apart the tv to clean it out?
the lower rear board must be removed.
To remove the lower rear board, remove the 15 screws
To remove the Back Cover, remove the 18 screws all
around it.
Use extreme caution here, as the mirror is fragile and
when the last screw is removed, the back can fall down and damage the mirror. Use additional help and allow them to hold the back cover while removing the last screw.
After taking off the Back Cover, the cabinet light cavity will be exposed.
May 27, 2010 | Hitachi 53UWX10B 53" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
My plasma screen has dimmed
i have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Nov 08, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Cleaning of mirrors
good luck
Apr 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dark picture ,cant brighten picure,
this worked for me
good luck
Apr 17, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
