Question about Samsung LN-R408D 40 in. LCD HDTV
Samsung LNR408D 40 in. HDTV
Every 15 to 20 minutes the screen blacks out. I have to restart the TV to see the picture again.
Any help on this issue will be appreciated.
    Problem Solver:
  • 15 Answers
Sounds like a backlight going bad or possibly the inverter. Check each backlight first for dark discoloration on the ends. If that checks out good then it's the inverter.
Posted on Jan 03, 2009
SOURCE:
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
I have a samsung lnr408d that has an issue. I
I'm curious, what were your TV's symptoms before you swapped power boards?
Does you're TV have an "a/v board"? that is, an integrated controller for both the LCD and the speakers that is separate from the motherboard? I've never seen them integrated like that, but if so, you might try replacing it because it sounds like a cheap solution.
The most likely problem however is the motherboard, which as you probably know can be pricey to replace.
Mar 19, 2010 | Samsung LN-R408D 40 in. LCD HDTV
My Samsung LNR408D TV is having color problems...
I would replace the main board (Audio/Video Board).
Nov 08, 2009 | Samsung LN-R408D 40 in. LCD HDTV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung LN-R408D 40 in. LCD HDTV Logo
191 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
