How do I replace a drum paddle in my Hoover washing machine HSWF167
I need to replace a drum paddle in my washing machine. The current one has broken and is snagging the clothes!
How do I remove the old one? Do I need to take the drum assembly apart?
  • ssedkt Mar 18, 2008
    Thanks for your comments.
    there is no cap on the top.
    On the new one I've got, it looks like there is a screwhole in the underside, which implies removal of the screw from the outside of the drum?
  • Anonymous Apr 19, 2008
    The paddle has broken in the drum of my hoover washing machine. It is loose but will not come out, appears to be fixed by screw.Does this mean I need to remove the whole drum just to fix new paddle?.
  • 8,617 Answers
There should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Posted on Mar 17, 2008
How do i change a drum paddle in my hoover HNWL 7166 washer dryer
There's a screw holding each paddle in place, as well as the lugs on the paddle. You can get to the screw by removing the drain hose from the bottom on the drum, and the paddle will then be free to slide out
Jul 09, 2011 | Washing Machines
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Plastic padle on inside of drum broken
Yes the paddles can be replaced. www.bellparts.com type in your model # and locate the paddles.
I hope this helps you.
Vic
Jul 12, 2009 | Washing Machines
How to remove and replace the paddle on a Hoover HSE140 Washing M
pull the paddle towards yourself and lift up it should come out to replace reverse instruction
Jun 23, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
2,119 people viewed this question
Top Washing Machines Experts
