Question about Philips HTS3450 System
How did u fix it
How did u fix the problem of the sound. my system too is acting up ther picture but no sound
  • wmhechler Apr 06, 2008
    I have the Philips HTS3450 DVD home theater system. I have had it for over a year now, and love it, except.... In the past couple of moths we recently moved. After hooking up the system exactly like it was premove, I get a clicking sound that starts out spaced apart, and progressivly gets closer, and closer, until it becomes one high pitched sound from all my speakers. It reminds me of some kinda of warming up sequance. It started out rather quickly, and over the past few months has gotten longer and slower. There is no sound until it goes through this routine. once its done, all is well, until.... Today, no clicking, no progression to a high pitch union. Nothing. So now I have no sound what so ever. I have double, and tripled checked all connections. Recycled the power several times. Double and tripled checked all settings too. I do not know what could be wrong....
  • Anonymous Apr 06, 2008
    Bought the Philips HTS3450 about a year ago. A couple months ago it started "buzzing" on startup...a few seconds at first, then the buzzing got progressively longer and longer. Today it went for over 20 minutes before I finally got tired of it and unplugged it from the TV. So now I have the sound from the TV alone. I miss the home theater sound, but apparently these things are pieces of **** that work for a year and poop out on you.
  • 20 Answers
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Posted on Jul 26, 2008
WheatService's advise worked. It wasn't hard at all. I pulled out the bad capacitors with plires. Then I put the new ones in and soldered them in from the back.
Posted on Aug 16, 2008
    Sergeant:
    Champion:
  • 319 Answers
Obviously something is wrong with circuits. Have it checked by pro/tech
Posted on Apr 22, 2008
Audio Problem
Refer this problem to the point of purchase. Your system should be under warranty so act promptly to get resolution.
Dec 06, 2013 | RCA Audio Players & Recorders
We have a Panasonic Plasma TV and are experiencing TV signal issues when our Bose sound system is turned on. Is ther anything we can do to improve the signal when the Bose is on (signal fine when we t
Move the insulated cables for the bose away from the cables to the tv. Or go buy monster cables for the TV so there wont be interference. Sounds like power cables are interupting the picture.
Sep 20, 2012 | Panasonic Televison & Video
Had hd but no more now ther is sound but no picture with regular cables
Hold the power button down for 5 seconds to revert back to standard definition.
Hope this helps
Aug 01, 2010 | Sony PlayStation 3 40GB System
Screen goes black
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
May 19, 2009 | Sony KV-32XBR450 32" TV
Lg 42" has no picture. but has sound.
Ther aren't any customer fixes for these plasma TVs. When you have no picture on a plasma TV there as many as 4 different circuit boards that could cause it. Sometimes it will require the replacement of more than one board. Call LG fro help. Depending on the age of the TV they may help with repair costs. At the very least, they can refer you to a local factory authorized service center.
michtech
Feb 19, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Philips HTS3450 System Logo
129 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
