Question about Brother IntelliFAX 2800 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
Poor quality fax to fax, copyies great, computer fax great.
Used Staples toner cartridge and immediately had problems with quality. Tried a new Staples toner and still had black ink all over the print. Replaced toner with Brother Toner and still same problems. HELP
  • 42 Answers
Beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Posted on Mar 17, 2008
Poor print quality
There are three main reasons why you get defective printouts - toner cartridge, drum unit or the fuser assembly. Clean them with non corrosive solution or replace when necessary. That should set the printing back to normal.
Dec 14, 2012 | Brother IntelliFax-2820 Laser Fax
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
Fax quality poor when recieving fax from samsung scx 4521F
Good Day Sir, Hope my suggested solution will resolve your problem.
Condition: The incoming fax has a blank spaces or is of poor-quality.
Solution:
  • The fax machine sending you the fax may be faulty.
  • A noise phone line can cause line errors.
  • Check your machine by making a copy.
  • The toner cartridge, referring to "Replacing the Toner Cartridge".
Redistributing the Toner
  1. Open the Front door.
  2. Pull the toner cartridge out and remove it from the printer.
  3. Gently shake the toner cartridge from side to side five or six times to redistribute the toner.
Have a nice day and God bless.
Oct 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
Poor copy quality
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Jan 09, 2009 | Dell 1600n All-In-One Laser Printer
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Poor quality of copies
If it is a real genuine Brother toner. Not a reman. You may also need to change the drum. If you have a user manual, it will show you where the drum life setting is in the menu structure. Make sure the little glass window inside on the right is clean so it can read the toner level. Make sure the toner save feature is turned off.
Aug 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
227 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
