Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Not cooling properly
I have changed the settings in my refrigerator either it is too cold meaning the food is frozen or it is too warm and not cooling at all. What is the problem??
    President:
  • 1,314 Answers
First the freezer does all the colling for both sides the fridge control just opens a damper door to allow air flow from the fridge if your frezzer is set to high turn it down some and put the fridge on the mid point setting also in the fridge side on the left about halfway down is a vent make sure nothing is blocking it reply with your model number so i can see who made it as kenmore don't make their own appliances and we will go from there
Posted on Mar 17, 2008
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Mar 25, 2014 | Maytag MBR2258XES Stainless Steel
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
May 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer ok, but refigerator is warm
first check to see if the controls have been changed,
one of the dials control overall cooling (freeser) and the other controls a damper that allows cold air from the freeser to travel to the refrigerator.
the other solution could be that there is something in the freeser, food or ice blocking the vent.
one other possibility is that the damper is stuck or frozen still.
if your freezer is ok, it is not a serious problem
May 26, 2009 | Refrigerators
Freezer and fridge is warm, cold air blowing but freezer is still
Try this, I went to the freezer side pulled the inside back panel (had to defrost it to get it out) and it was completely frozen over. It was not not operating properly because the cooling coils would not allow the fan to pull air through them to cool the refrigerator side. I completely defrosted the coils and turned the refrigerator back on, it worked fine. I then ordered a new adaptive defrost assembly (this is the thing that prevents the ice buildup) since ours was apparently not working properly. I used a fan too speed up the defrost process, because i had to take all the frozen food out and put it in a cooler to get to the back panel. After you take out the racks and food you only need to remove two screws that have a 1/4' head. good luck.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerator trouble shooting
Condensation only ever happens if the door is left open for a long period. - The warm ambient air condenses on anything cold - like the food in there.
Because of convection, the door need only be open 1/4" to be affected. Quite often a bag pushes the door open a little.
Check all door seals for splits - clean them.
Make sure nothing is touching the back cooling plate, and it should be fine from there.
Hope this helps.
Jun 11, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
