Question about Dryers
Amana Dryer Model LE100(P7762201W)
Need to know how to properly install wire harness in back....
    President:
  • 1,314 Answers
If its a three wire coed put the middle terminal of the cord to the middle terminal of the terminal of the block then one outside terminal of the cord to black and the other to red all that really matters is the middle or round terminal of the cord going to the middle make sure they are tight and slip the little round parts of the strain relief in the round part of the terminal block cover and put the screw in it
Posted on Mar 17, 2008
My Amana electric dryer, Model # NED4500VQ0 is not heating clothes enough to dry a load in one cycle. I changed the thermostat already. The back glows orange and is heating. I figure it has to be the...
Not sure about the hh limit or the element, but make absolute certain that there is good flow of air. Check to see if the vent is clogged. Remove the hose from the back of the dryer and see if air is flowing very hard. Use a vacuum cleaner or a wire or something if it is clogged. Similarly, check the hose itself. If the hose collapses when you attach a vacuum to it, it is clogged. Dryers require heat AND air flow to dry properly. :)
Mar 22, 2012 | Amana Dryers
Amana dyer model ale956eaw, won't heat up, all
if all other operations of your dryer are ok possibly your heater element or thermostat are faulty also there may be damaged wiring you will need to look closer and own a multi meter to check properly keep me informed of how you went
Nov 07, 2009 | Amana ALE956EA Dryer
Need to change cords
If your dryer has only the three treminal block you should change the recptacle to a 3 wire. The difference in the 3 and 4 recptacle is that you have 2 hots, a neutral, and a ground prong. Find your dryer breaker in the box and just use the 2 hot and the neutral. Unless you can find a four terminal block for the dryer and even then would it mount to the dryer? Probably not. The extra ground simply grounds the cabinet to prevent damage. Your four wire recptacle may have a red and black(hot) a white(neutral) and a green or plain copper(ground)
Apr 06, 2009 | Amana Dryers
SCD25TW Amana 1998
the fuse for the i/m is actually in the wiring harness that plugs into the icemaker. if the model is correct the icemaker goes across the back of the freezer. when you installed the icemaker on one of the wires (i think red wire) there is a black "pill" looking thing. this is the fuse.
Feb 23, 2009 | Amana SXD524VW Side by Side Refrigerator
Heat in dryer not hot enough, runs cool not hot
You may have a leg of power out. First turn off the breakers, then back on to insure a good reset. Then check the wiring at the receptacle, then the plug, then the wiring to the back of the dryer. This may be the problem. Have you cleaned the lint tray?
Feb 10, 2009 | Amana ALG331RAW Gas Dryer
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a...
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Jul 15, 2008 | Amana Dryers
Installing dryer belt on amana LE2910W
Please view Amana dryer belt installation diagram amana.gif Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
Disconnect dryer from the power source before servicing!
In assuming that you already have the front removed, you can raise the top by removing 2-5/16" screws located in each front corner that secure the top to the side panels. Then remove th 4-5/16" screws from the bulkhead that secures it to each side panel. Then use the diagram above on installing the belt properly.
Let me know if you need any more information.
May 28, 2008 | Amana Dryers
Wiring harness diagram
which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Mar 17, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
