Question about Radio Communications
Intercom/baby moniter - buzz/hum
Recent purchase - replaced, same problem - loud buzz or hum on transmit
Could never use as baby monitor - buzz all day would drive you nuts.
Bad product? - need filter? - problem with my house wireing?
sounds like an old tube type amp. with a bad ground. No problem with any other electronics in the house
  • Anonymous Mar 07, 2009
    Baby monitor hum is intolerable, you can turn the volume down but it kind of defeats the purpose of the baby monitor. No pwerlines or transformers in the area, I'm wondering if another home electronic is interfering, my wireless router for example.
  • jmerrix May 11, 2010
    Do you live near a lightpole transformer?
Ok do you live within 1km of a sub station. As these produce a high emf output and can affect radio equipment in a similar way???
Posted on Mar 19, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have kenwood amp m-a100 which has loud buzz / hum on all channels and distorts radio very badly can you help ?
The loud hum will be probably caused by the Large Electrolytic Capacitors in the Power Supply section. All of them will need to be replaced to be on the safe side. The buzz noise is caused by the fact they are letting in the 50/60hz mains. Hopefully that should clear everything up.
Sep 09, 2014 | Audio Players & Recorders
Can you make a baby monitor out of the Motorola 250 model
hello yes you can use these as baby monitors .set one with vox on turn its volume down completly set the channel you require ,secondly the receiver radio set to same channel and that is it though i should state that these radios transmit on pmr band 446 mhz which is widely in use by many people nationwide so they can also listen in to whats been transmitted from your home not very private im afraid !! I would suggest you purchase a wired system hence more privacy and peace of mind hope this helps you
Nov 24, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
Screen is trying to black out on me, accompanied by a loud buzzing noise. This buzzing noise has been growing over the past few weeks, and now, today, my monitor has blacked out several times, at which...
well mine came with a three year warrintee, so iv sent mine back twice already, worst moniter, try finding your receipt and then going on to acer's online support
Dec 15, 2010 | Acer X233H 23" Monitor
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Buzzing or humming rear passanger tire
Hub bearing in the right rear is the most likely problem
Mar 27, 2009 | 1994 Honda Accord
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Radio Communications Logo
576 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
