Question about LG WD-3243RHD Front Load Washer / Dryer
Lg wd-3243rhd front load washer and dryer combo "le" error message
I bought a house with the LG 3243 (about 4 years old) already installed, no owner's manual. This morning, after starting a small cotton load on "Auto", I notice the digital display said "le" and the clothes inside were still wet.
I tried to start a "dry" cycle, but it stopped shortly after starting, again giving the "le" message.
I can't see where I can access the hose to try to clear a clog.
Any suggestions.
Thanks
  • Anonymous Oct 25, 2008
    We bought LG washer drayer only 2yrs ago. I getting this same LE error msg. I have no clue how to fix this problem.
  • Anonymous Mar 20, 2014
    LG front loader is clogged. Clothes were wet after cycle
  • 489 Answers
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Posted on Apr 28, 2008
This web site has a copy of manual. I found it by searching in Google for: lg wd-3243rhd manual
The manual gives LE as meaning there is a motor overload, which may well mean a faulty sensor.
Note that the manual warns against putting stuff of the top of the machine because this can cause overheating.
Note also that CoolTech sounds experienced. I just read manuals.
Posted on May 30, 2008
    Champion:
  • 210 Answers
You don't have to get a complete motor. The only thing that is gone most likely is the Hall sensor. Runs about $20. You will have to take off the Rotor and stator and it clips onto the stator. Be careful when putting the rotor back on as the magnets pull it back in and if your not careful you will pinch your fingers.
Sgt 48
Posted on May 31, 2008
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
I have an LG WD 3243RHD washing machine/dryer combo and it is displaying LE. Is there anything I can do without calling a repairman?
LE on this machine indicates a motor error. The connector in the lead wire assembly is not connected to the connector of the stator assembly. You need to reconnect or repair the connector. Also, it could mean that the Hall Sensor is defective and you may need to replace the Stator Assembly.
Nov 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG 3243 not draining
Take the drain filter out and look inside the drain tube with a flashlight.  Usually, you will find a small sock blocking the drain hose inside.  If you can see it, you can use a coat hanger to pull it out.
May 03, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WD-3243RHD Front Load Washer / Dryer Logo
947 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
