Canon S750 Bubblejet Printer paper jam--now won't print
I have the printer model mentioned above. While attempting to print something, the paper jammed inside the printer. So I removed the paper that jammed and made sure the paper was aligned properly in the tray, but the printer wouldn't print (even after totally powering down and unplugging-then plugging back in and powering back up). Now when I turn the printer on, I see an intermittent green light followed by 7 orange light flashes. The manual says this means the printhead is defective. How can my printhead be defective all of a sudden after 1 peiece of paper got jammed? I also noticed (in the paper feed area) that there was a smooth oval-shaped piece of metal, maybe 1 1/2 by 3/4 inches in size, with a metal peg on the concave side of it. I have to believe this came from the printer, but I could be wrong-- Any ideas would be greatly appreciated!
Thanks,
Gabriella
    Guru:
  • 377 Answers
Hi dear
try this
anon GENERIC “S” SERIES RESET CODE Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer’s carriage will “reset” or move momentarily. If the above was properly performed the printer will enter the “Service Mode”.
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!) After selecting the desired mode (eg 4), press the POWER button to “set” the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
oke
cropp
Posted on Mar 19, 2008
SOURCE:
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
HI, I HAVE CANON LBP 2900 I I TURNED OFF THE POWER WHILE IT WAS PRINTING , THE PAPER STUCK INSIDE, I TRIED TO REMOVE IT BUT I COULDNT THANK U
Hi,i recently had a paper jam problem with the Canon ImageClass MF3240. I followed all the possible fix to remove the jam, but after clearing the paper in all access doors, the printer still gives the paper jam error. Restarted the printer several times to no avail and the red light keeps blinking. Well here is something not suggested in the manual.
1. Turn off your printer.
2. Pull off all plugs attached to your printer back.
3. Remove the paper tray to look for the sensor located underneath the printer.
4. Get a flashlight and look closely. The sensor is located in a small hole, just above the small plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller.
5. There is a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
6. Get a small tweezer to remove that paper.
7. Return all cables and start your printer and that's it!
Hope this helps you as it saved me a big headache.
Also, How Come My Printer Won't Take the Paper?
Printer problems are a common occurrence. There are various reasons why a printer won't take paper. Printer paper sometimes can become jammed in the machine. It may be wrinkled or too big in size.
Computer Glitch
Printer paper also may be of poor quality or too thick. Paper may not be lined up correctly, and can jam within a printer as it goes through the feed. The power may not be on. Sometimes a printer that is attached to a computer can get knocked off track from too much printing, or a glitch within the computer system.
USB Printer Cable
Something as simple as re-installing the computer with use of a new USB printer cable may fix the problem, or unplugging the printer and then plugging it back in.
Printer Rollers
The rollers may be worn within the printer, and can't grab the paper correctly to guide it through the machine. If this is the case, the rollers will have to be replaced.
You can also use the below link :
support-th.canon-asia.com/contents/TH/EN/8000561401.html
Hope this helps you .
Thanks for using fixya.......
Nov 22, 2010 | Canon LASER SHOT LBP-2900 Printer
I keep getting error 6000 when I am trying to print how do I rectify this
Hi there
I think THE 6000 is the same problem error as the ERROR 6A00
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 19, 2010 | Canon BubbleJet i560 InkJet Printer
I lost my Manuel and when I try to print something
Here is a download page for your manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8046
as for the settings........
Go to0 the start menu, select "printers and devices"
select your printer, select printer preferences,
and change the setting from the menus.
There ya go!..........Please remember to RATE ME. Thank You.
Mar 08, 2010 | Canon BubbleJet i550 InkJet Printer
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam on my i560
there is a small paper very small paper stuck in the printer remove it it will work
Nov 09, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i9950 inkjet printer, keeps showing paper jam even though nothing there. If I turn it off and on, it prints anything from 1 to 4 pages before error message paper jam again. Just going round in...
Maybe it's just one small paper.
If it's on guarantee, take it to store, and describe the problem like this:
"Cant print. Don't know whats going on!"
So they don't charge you ;)
If it's out of guarantee, try to open all parts until you see the small paper.
Or it could be the sensor (piece of plastic) that was jammed, or get jammed when paper pass. Take a good look on that too.
Aug 27, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
Open Questions:
502 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
