Question about Dryers
Wiring harness diagram
Wires in the back of settings popped off during the move and we need to connect proerly
took off to fix belt...need to know how wires on back go to hook back up. Amana Dryer...model LE1100(P7762201W)
  • lindseyluka Feb 02, 2009
    I have a Whirlpool dryer that we bought 2 years ago and now it's not working. The service man said that there was something wrong with the harness..what does this mean...does it have anything to do with the circuit breaker or power outage?
    President:
  • Dryers Master
  • 2,651 Answers
Which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Posted on Mar 18, 2008
Need wiring diagram of rear-window defogger circuit for 2008 Chevy Impala LT
i just fixed my car to the exact question above, it took 20 minutes total. yes I\'m good with a wrench, but this fix doesn\'t reqire you to be.
Problem: Rear defroster doesn\'t work, but the fuse is good and the little light comes on on the button.
Answer: Go to front passenger kick panel where the "other" fise box is and remove the pastic panel, it just pops straight up. Under the fuse block is a white plug that connects front wire harness to the rear harness. this is where the problem is. pull the connector off the body, my plugslide straight back. Now flip the whole connector over, there you\'ll see the burnt spot on the plug. losse, corroded connection causes melt down. this stuff happens. my car has a purple wire going into the plug and a black one coming out, this is the rear defroster wire. cut the purple wire aleast a half inch before the plug and cut the black one coming out of the plug the same, always leave a little wire incase you ever want to reuse that terminal, standard rule. now take two butt connectoers and a four inch piece of ten gauge and splice the purple and black wires back together. lots of current so DO NOT use 12-14 gauage wire, it will melt. and Wa-La, its fixed!! since you dont have to do the trouble shooting and chase down the wires like i did, should take you ten minutes to fix.
Now if this doesn\'t fix your car, then don\'t pay me!!
If this DOES fix your car, then take your wife out to dinner with the $150.00 i just saved you from having to take it to the dealer,
(they would sale you new connectors and harness)
Oct 30, 2012 | 2008 Chevrolet Impala LT
I have a 1997 Chevy Venture. I replaced the fuel pump, and relay. Checked all the fuses, and they were good. We then proceeded to tear the interior apart and check all the wring by tracing from pump to...
Learning how to do automotive electrical trouble shooting . Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Reading wiring diagrams !
The Trainer 32 How To Read An Automotive Block Wiring Diagram
.Finding wiring diagrams
http://www.bbbind.com/free_tsb.html enter vehicle info year , make , model an engine size . Under system click engine , under sub system click fuel controls . Click the search button one link pops up , click on that .Third diagram down is fuel pump electric diagram . See there are two connectors in that wiring harness , C - 200 & C - 305 . Plus you will see the power wire is gray . Find the connectos check for B+ voltage along the harness
The Trainer 29 Understanding How Electrical CIrcuits Work and How to Test...
The Trainer 23 How To Repair Wiring and Wiring Connectors
Mar 27, 2017 | 1997 Chevrolet Venture
Remove and replace alternator
Just follow these steps to remove and replace the alternator. You will need this tools, Serpentine belt tool, Battery wrench, Lug wrench, Floor jack, Jack stand, Socket set,
  1. Open the hood, locate the serpentine belt tensioner and move the tensioner off the
    serpentine belt with the serpentine belt tool. Slip the belt off the tensioner
    pulley with your other hand and then slowly move the tensioner back to its normal
    position. You can pinpoint the location of the belt tensioner by following the belt
    routing diagram, printed on the fan shroud.
  2. Disconnect the negative battery cable from the battery with the battery wrench.
    Push the cable end away from the battery so it doesn't make contact during the
    repair.
  3. Turn the lug nuts on the right-front wheel counterclockwise until they're loose
    enough for hand removal, but leave them on for now.
  4. Lift the right-front end with the floor jack and support it on a jack stand placed
    underneath the right-front frame. Remove the lug nuts and right-front wheel by hand
    and set them aside.
  5. Slip the serpentine belt off the alternator pulley by hand. You can access the
    alternator through the wheel well. Unplug the wiring harness from the alternator
    by hand and remove the ground strap with your socket set.
  6. Remove the alternator mounting bolts with your socket set. Lift the alternator out
    of the engine well, through the wheel well. Insert the new alternator in reverse of
    how you removed the old one.
  7. Thread the alternator mounting bolt through the new alternator and into the
    alternator bracket by hand. Tighten the bolts with your socket set.
  8. Attach the alternator ground strap with your socket set. Plug the alternator
    wiring harness in by hand.
  9. Slip the serpentine belt over the new alternator pulley. Reinstall the wheel and
    lug nuts by hand. Lower the Taurus of the jack stand with the floor jack.
  10. Move the belt tensioner aside again and place the belt on the tensioner pulley with
    your free hand. Hold the belt on the pulley and slowly move the tensioner back to
    its normal position. Reconnect the negative battery cable to the battery.
Hope this helps you.
Take care and good luck
Jan 08, 2011 | 2002 Ford Taurus
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Automatic sliding doors
My door also had the same problem: It would only open a few inches, then it would stop. Moving it manually one more inch and trying again would make it go all the way. In my case, this was due to the wire harness being bent in a certain way right at that point (and the wires being broken there).
First make sure that the door moves smoothly over the location where it stops by moving it manually. If it's hung up on something, try to find it. In my case the door itself moves very smoothly all along the path with just a finger (or two) pushing it.
I took two screws off the top plate of the arm where the motor in the door meets the frame (bottom of door). I then took this plastic arm cover off. I could then see the wire harness and the gear. Now, make sure there's nothing major wrapped around the gear; next, see if you can get the door to start moving by pressing the button at the same time as you wiggle the wire harness. If the door starts to go, then it's likely a bad wireing harness.
I took the wiring harness out of the arm and moved it below the arm instead of within it. Now it works just fine (the harness doesn't bend in the same bad way anymore). However, I anticipate having to buy a new wiring harness to fix it for good.
Jun 29, 2009 | 2007 Dodge Grand Caravan SXT Minivan
I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
May 02, 2009 | 2001 Dodge Stratus
I need a 2005 Chrysler 300 wiring diagram
You don't need to touch your harness for the fog lights as its a major harness and is connected to many other things. You need to pop out the light switch opn the dash. it pops out and in the back of it you disconnect it. It has a conector on it. Buy a new switch at dealer, aprox $90 canadian and snap it back on. I know my fog light switch went last year. I have same the same car.
Dec 10, 2008 | 2005 Chrysler 300
Console wiring damaged during breakin
Here is the wiring info for your radio. I have some other wiring diagrams but did not see anything related to your ac. Hope it helps and let me know if you want the other wiring diagrams. Also once you know what these wires are then you will be able to tell what wires are not related to your radio and might be able to figure out which wires are causing your other problems?
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE(+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Oct 09, 2008 | 2002 Hyundai Accent
Dryers Logo
268 people viewed this question
Top Dryers Experts
