Question about Symbol PDT 6840 Wireless Portable Terminal
HOW DO YOU OPEN THE 6840
IN TRYING TO REPLACE THE FOAM GASKET THAT GOES WHERE THE COMMUNICATION DIODES ARE AFTER I REMOVED THE 6 HEX SCREWS IT STILL SEEMS STUCK
What is the Head Bolt Torque specs for a 25HP Kohler Pro CV7308?
Heads Secured With Screws
1. Check to make sure there are no nicks or burrs on
sealing surfaces of cylinder head or crankcase.
2. Install a new cylinder head gasket (with printing up).
3. Install cylinder head and start four new hex flange
screws.
4. Torque screws in two increments; first to 22.6 N·m
(200 in. lb.), then finally to 41.8 N·m (370 in. lb.).
Heads Secured With Mounting Studs, Nuts, and
Washers
2. If all studs were left intact, go to Step 6. If any studs
were disturbed or removed, install new studs as
described in Step 3. Do not use/reinstall any
loosened or removed studs.
3. Install new mounting stud(s) into crankcase.
a. Thread and lock 2 mounting nuts together on
smaller diameter threads.
b. Thread opposite end of stud, with preapplied
locking compound, into crankcase, until specified
height from crankcase surface is achieved. When
threading in studs, use a steady tightening motion
without interruption until proper height is
obtained. Otherwise frictional heat from engaging
threads may cause locking compound to set up
prematurely.
Studs closest to lifters must have an exposed
height of 75 mm (2 15/16 in.).
Studs furthest from lifters must have an exposed
height of 68 mm (2 3/4 in.).
c. Remove nuts and repeat procedure as required.
4. Check that dowel pins are in place and install a new
cylinder head gasket (printing up).
5. Install cylinder head. Match numbers on cylinder
heads and crankcase. Make sure head is flat on
gasket and dowel pins.
6. Lightly lubricate exposed (upper) threads of studs
with engine oil. Install a flat washer and nut onto
each mounting stud. Torque hex nuts in two stages;
first to 16.9 N·m (150 in. lb.), then finally to 33.9 N·m
(300 in. lb.).
Aug 19, 2014 | Craftsman Garden
My Alesis Interactive Mobile Amp seems to have a dead battery. I was keeping an eye on the charge lights, and when it went from 3 green lights down to 1, I plugged it in to charge the battery back up. ...
change the battery, its quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
May 30, 2011 | Alesis TransActive Mobile PA System...
Battery has died how do I replace it?
you need:
e) some glue
... yes thats all.
here we go
DISASSEMBLY
ASSEMBLY
Jan 18, 2011 | Alesis TransActive Mobile PA System...
The handle of my side by side Kitchen Aid refrigerator is loose. The model number is KSCS25INSS00. It has circular open holes on the handle, no screws? How do I tighten it?
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
May 21, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
1999 Beetle: cabin air filter 1999 beetle replace...
You will need to slide the center hump on dash directly above radio and vents backwards towards the widshield. You will notice a crease where the actual part containing vents meets the center hump that is just one piece itself. It should open up giving you access to the right side (passenger side) dash panel that has 5 or 6 screws (they are hex) that need to be removed. You will find the Cabin air filter under this panel after removing screws. it pulls out easily and the new one just sits back in place. Replace the screws and then align and slide the center hump back towards the back of car to lock into place. Relatively easy thing to do..
May 18, 2010 | 1999 Volkswagen Beetle
Opening bose on-ear headphone speaker's cup
Apparently there are screws hidden in the small foam ring covering the plastic (not the earcushion). Try it removing the foam and tell me how it goes!
May 02, 2010 | Bose in-ear headphones - Black with...
How do I replace the group gasket?
1. empty the water tank
2. turn machine upside down
3. remove shower rose(one screw in middle)
4. remove group head (two hex screws)
5. pry out old gasket
6. fit new gasket and reassemlbe
Dec 25, 2009 | Gaggia Classic Espresso Machine
Water pump is out. How do I get id out to replace
is it a 4 or a 6 cylinder engine, well you need to take off the fan clutch if it has one if not skip the step; its just 4 screws, then take off the acc belt, then take off the hose that goes from the radiator to the water pump; at the water pump, then remove the screws holding the water pump; make note what screw goes where some screws may be different sizes; in some 4 cyl 2.3L engines the timing belt cover has to be removed to remove the water pump, then remove the water pump, scrap off all gasket residue from the surface of the engine, take automotive silicone gasket maker and apply a small amount to the new water pump and level it out then put the included gasket over the silicone, then let it set for a couple of minutes, apply a bit more of silicone over the gasket and again let it set then replace the water pump, replace the screws and tighten all of them snug then go back and torque them between 20 and 25ft lb, replace the water hose, replace timming belt cover if removed, replace acc belt, and finally replace the fan clutch and your all set i hope you can get the job done
Jul 27, 2009 | Ford Ranger Cars & Trucks
Velodyne Hgs- 15x
The driver has a soft foam rubber gasket behind it. It can act like glue on the driver.
Taking the driver out will tear up this gasket, always does, so don't worry about that.
You can try to lever the driver out. Use care not to scratch the baffle.
Apr 08, 2008 | Velodyne CHT-12 Subwoofer
Symbol PDT 6840 Wireless Portable Terminal Logo
44 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
