Question about Sony Handycam DCR-TRV103 Digital Camcorder
Playback Hi, I have been copying my tapes from my Sony to DVD with success until I experienced tracking problems which seem to essentially be the digital tapes or at least 80%. They play with hesitation and skips like an old LP. I have nearly 25 tapes to burn and of course this camera is now going the way of the dinosaur so I cannot replace it easily. I look forward to your suggestions. I've been copying my Digital8 tapes recorded over the past 8 years to my computer hard disk using my camcorder. I had completed around 20 tapes last year with no problems at all. I restarted the project about a week ago. My tapes playback showed similar problems described by others (like it was skipping every second - both audio and video - like it has problems syncing. I never had this problem before. Whats more, I borrowed two other identical camcorders from friends which also started showing the same problems and these camcorders seem to have been affected similarly - they have trouble playing tapes owned by my friends also.
  • 3 more comments
  • srisan Mar 18, 2008
    I seemed to have solved my problem, but still do not know the cause. Here is the solution I posted for someone else.
    I had this problem very recently. In fact I borrowed camcorders from my
    friends too and after short periods, they too started having the same
    problem. Essentially, it looks like there is some choppiness every
    second or so - like there is noise in the audio and video. After a lot
    of looking around, I finally found a suggestion posted that ACTUALLY
    WORKED on all 3 camcorders:
    I placed an empty tape in the
    camcorder and recorded a few seconds into it. Then I removed that tape
    and tried to play the previous tapes that were showing the choppiness.
    No problems any more. Everything works fine.
    What I still do not
    understand is why 3 camcorders (all DCR-TRV103s) all showed the same
    problem (with different tapes by the way). And since I still have lots
    of tapes to copy, I need to know why this problem is happening so I can
    minimize its occurrence while I complete the copying process.
    People
    have suggested that my tapes are old and may be offering resistance to
    the camcorder. So I have ordered a rewinder to spin the tapes a bit
    before trying again. The two possibilities suggested around this was
    (1) some mechanical switching took place which got reset when
    recording; and (2) something got corrupted in the software that manages
    the playback buffer and that software was rebooted when it went to
    recording mode.
    So while this will hopefully answer your
    question, I'm also looking for explanations for why this happened to me
    on 3 different camcorders.
  • Anonymous Oct 01, 2008
    Thanks! I had the same problem and I was ready to give up. Your method worked just fine. I just recorded onto a cleaning tape for 5 seconds and now it plays without any issues.
  • fciof Jan 08, 2009
    Thank you! I had the identical problem and was ready to search for a replacement. Your suggestion worked. Thank you for sharing this fix.
  • Anonymous Feb 23, 2009
    Thank you thank you thank you for the "record a few seconds" solution to this problem. I was having the exact same playback issues with my TRV103, and tried this fix and it worked beautifully; my camera is back to normal.
  • spalaw Apr 11, 2009
    Brilliant!!!!!! I have had lotS of video from 5+ years ago that I never watched because my old Sony camcorder had a tracking problem that I never had fixed. I am glad I saw your post! I had paid to have the same problems fixed in the past. I finally just read your solution and it worked perfect!!!!! You have made me soooo happy!!!! Now I can watch the kids old videos again. THANK YOU.
Recording and playing a new tape worked for me too. Thanks!
Posted on Oct 31, 2008
  • david2stars May 29, 2011
    Great solution, still don't know what cause the problem. But I did put in a new tape and recorded for 15 seconds then rewind and replayed OK with no audio and video hesitation. I then reload my old tape and played OK. This is a very strange thing that could happen to a video camera. Well, technology glitch in software. Thanks for the suggestion...
VCR playback issues
I had a similar issue with a DVD player, in that it wouldn't play any commercial or rental DVD's, but it would play them if I burned a copy on my laptop. Turned out to be board inside the machine. I had to replace it.
Jun 18, 2008 | Philips Magnavox DVD/VCR Dual Player
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Copy tape to dvd using Q-VHQ 760 & Pinnacle instant dvd recorder. Playback looks great, unfortunately there is a thin fuzzy line at the bottom which never changes. My question - how can I fix this ? ...
Check the edge of the tape to see if it's wrinkled. That is the most common problem that shows that line. You may be looking at the head switching pulse too. Since your VCR has no tracking adjustment, it has to be done with special tools, an oscilloscope and a voltmeter. Not an easy task.
Feb 15, 2018 | Quasar VHQ760 VHS VCR
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Old Sony Handycam Video 8 CCD TR36
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
Dec 27, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Playback
most likely needs to have the heads cleaned, running that many tapes can clug your video heads. if this still does not work the take up tension might be a little low. you can fix this for free, but try having it cleaned 1st.
Sep 17, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Won't playback copied dvd's, only commercially made ones.
Read here and we can see that other people have both trouble and success running back ups on this device: http://www.videohelp.com/forum/archive/anyone-experienced-with-b-u-s-playing-on-a-sony-dvp-s7000-t283487.html So... That tells us this device is finicky IE it requires a high quality burn. DVD burners have varying levels of accuracy. To improve your burn: -SLOW the burn speed for increased accuracy -USE DVD-R only as it is the most compatible -Use those Sony's DVD-r's at wal-mart or KMART because Sony makes DVR's and everyone else buys them from generic Taiwan manufacturer and relabel I bet this will solve your problem. After you get a successful burn at 2x try 4x then 6 etc.
Aug 27, 2007 | Sony DVP-S7000 DVD Player
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-TRV103 Digital Camcorder Logo
391 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
