Question about Vacuums
Vacuum cleaner stopped working while vacuuming. Turned off unit and it would not go back on. All electrical outlets tried and it still did not work.
    Sergeant:
    Champion:
  • 306 Answers
The power coupler might be faulty, price the coupler and the decide whether its cheaper to replace it or the vac.
Posted on Mar 17, 2008
    President:
  • 1,314 Answers
Take the handle and check the on off switch
Any ideas on why my vacuum cleaner would quit working?
the on off switch perhaps .then the motor itself
May 12, 2015 | Vacuums
Electrolux mondo z1175 vacuum cleaner not working.
Do not get upset with me, but I must ask this question!!! 1) Did u try any other appliance in that outlet, or 2) Did you go back to the original outlet to see if the vacuum works there? It is kind of a coincidence that it quit working only after you moved it to another area. Let me know please!
Nov 15, 2014 | Vacuums
Vacuum stopped while sweeping the floor
it is either the switch or the motor buy a brand new switch to put on it and if that does not solve the problem then the motor is just trash but the switches go out on these kinds of vacuum cleaners all of the time so that is probably the problem but if not the vacuum is trash
Mar 23, 2014 | Hoover Vacuums
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
Vacum shuts off
If you have BISSELL vacuum, some of our models have a brush reset. Here are the instructions to turn it back on:
If something becomes lodged in the foot and the
brush shuts off, turn the cleaner off and unplug
from the outlet. Remove the obstruction. The
brush will automatically reset when the cleaner
is plugged in and turned back on.
Additionally, you could have dirty filters that are activating a thermal protector switch that shuts the vacuum off if the motor becomes too hot. If this is the case unplug the vacuum, clean any filters, clogs, or obstructions and wait 30 minutes for the unit to cool. Then plug the unit in and it should work. I hope this helps.
May 03, 2012 | Vacuums
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Vacuum is not turning on. Is there some kind of a reset switch or a fuse that could have gone out?
There is no reset switch. First try a different electrical outlet. If that doesn't work, you may have to replace the power switch. Call the Dyson Helpline, they'll register your vacuum cleaner and direct you to your nearest repair dealer.
If your machine turned off whilst you were using it you have a blockage in the machine and you are experiencing a Thermal cut-off. Call the Dyson Helpline, they will talk you through looking for a blockage and help you find it.
Jul 11, 2009 | Dyson DC14 All floors Bagless Upright...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Electric motor does not work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=784776
Posted by prajuabmcb on July 14, 2008
Electric motor does work when switch is turned on. Tried different electrical outlets but still not work.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil 12 Amp HEPA filer vacuum cleaner. It sounds to me like you may have a 2 motor system according to the picture and it also sounds like it could be the bottom motor of which if it is not working well then it may need replacement – there is really nothing you can do for the brushroll motor other than replacing it. Question? Do you have any suction from the main motor? If you do then it definitely is the brushroll motor that needs replacement. You can always check your Royal owners manual under the trouble shooting guide or you can contact the Royal cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
83 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
