Question about Panasonic SA-XR25 Receiver
Receiver has lost audio
Static, snapping noise; garbled, broken audio.
notice that the fan in the rear of the receiver is not working.
fixable, or do I have a blown receiver?
  • 3 more comments
  • Anonymous Jun 26, 2008
    I have exactly the same problem. However, mine does it every day at random times. Like you said sometimes no probs, then boom every 15 min. Then stops and won't have a problem for a day or so.
    Any help would be appreciated! I really like the receiver for everything it does, but this is very annoying.
    cr
  • dsbeach1 Nov 26, 2008
    Same thing here as well. Lost audio, just hear crackling. When its on DVD mode the crackling becomes much louder and even more irritating. Anyone hear if this means its blown or not?
  • maxxer Nov 28, 2008
    same problem with the garbled and snap-crackle-pop started when I moved the receiver- worked great before
  • abennani Nov 29, 2008
    Had this problem for a while, I would just switch on an off the receiver and the sound would be back to normal. Now, I have no audio at all, just crackling sound.
  • Figment123 Feb 14, 2009
    I have the same issue.
There are four surface mounted caps, 22uf/10v under the surround processor PCB on the main PCB.
Just replace them all.
That took care of my static problem.
Posted on Feb 25, 2009
6ya staff
SOURCE:
I have a cobra 29 classic ltd black and chrome bt edition, no matter what antenna i use or how low my swr is i still receive nothing but static all day on all 40 channels. i can transmit just fine but my...
The problem may be in the audio output chip mounted on the chassis, also! there is also a small capacitor located next to the audio chip that has known to be a problem, finally sub the speaker for another, often a source of trouble.
Aug 31, 2012 | Cobra 29 LTD CB Radio
Metal snapping noise, like a broken spring, now burning smell. clutch?
Sounds like the throw-out bearing or the pressure plate has gone out..
Jun 24, 2017 | Cars & Trucks
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Lenoxx DVD-1000 Audio does not work
Check for the capacitors around output amplifier.Easy to fix
Mar 11, 2009 | Lenoxx Electronics DVD2003 DVD Player
Static
CB radios use a frequency range and technology that is prone to noises both atmospheric, and man made. The height and gain of your new base antenna may produce more static than you may have noticed before. The question is 1) is the antenna close to any power lines to your home, 2) do you notice any increase or decrease of received signals compared to your mobile, 3) is the static steady or does it come and go.
Nov 07, 2008 | Radio Shack TRC-503 CB Radio
Heavy static noise
Sounds like interference getting in caused by your connecting cables. Suggest upgrading to higher quality ones.
Aug 31, 2008 | Sherwood RX-4103 Receiver
Reciever malfunctions after 30 mins use
This receiver runs VERY hot during normal operation. Make sure you provide good ventilation for it.
With summer here, you might consider a small clip-on fan and clip it near the top of the receiver. The amplifier section is along the front of the chassis - so that's the source of heat.
See if unblocking it helps - then try the fan.
Aug 29, 2007 | Onkyo TX-SR304 Receiver
Panasonic SA-XR25 Receiver Logo
746 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
