I have recently bought an Acer monitor model X193W and would like to mount it on the wall. However, I can’t see how to remove the whole stand. I have removed the base but the stem is still attached. Can you help
  • Anonymous Jun 01, 2008
    what sort of wall mount do i need and where can i buy it?? what is it called??
  • 52 Answers
There should be 4 screws attaching it to the stand unscrew them and attach wall mount
Posted on Mar 17, 2008
How to remove the stand of ACER LCD monitor H163HQ?
You should see a ***** located on the round base,just remove that with Philips(star) ***** driver and that`s it :)
Jul 31, 2014 | Acer X193W LCD Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I have an Acer X193W....looking into the blue light on the power button it seems "dark" at the middle of the power switch light.....is this a burnt out light or do I see an internal part that is...
You are right. You are seeing an internal part that is in the middle of the light.
Specifically, the light is an LED (light emitting diode) the part you are seeing is the stand on which the actually silicon chip is mounted.
Jun 22, 2011 | Acer X193W LCD Monitor
Just bought a acer x193w lcd monitor no sound
I assume the monitor has speakers built in . Have you plugged the sound card in to the monitor?
Jun 03, 2009 | Acer X193W LCD Monitor
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Acer Monitor Stand removal
On the rear of the monitor stand, just 1/2" above the word "Acer", is a rectangular button. push it in and pull the stand off . If you need to remove the rectangular tube, there are two snap on covers, one on each side of the tube. Pop them off and remove the screws underneath. That's it.
Feb 22, 2009 | Acer X193W LCD Monitor
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
How do I remove the stand?
Looking at the manual
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=761&formid=3425&website=AcerPanAm.com/au&siteid=8116&words=all&keywords=&areaid=12
It doesn't appear to accept a standard VESA mount to enable mounting on anything other than the supplied stand.
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
Computers & Internet Logo
113 people viewed this question
Alun Cox
David Payne
David Payne
