TV PARTS FOR SOYO
I NEED THE POWER SUPPLY BOARD PRICE AND WHERE TO GET IT AND THE SMALL SIGNAL BOARD PRICE. FOR SOYO MOD# DYLT032A
  • Anonymous Aug 18, 2008
    yes we are a service center & there are no soyo parts avoid buying junk Pete
    Problem Solver:
  • 6 Answers
Call mr.tv in ct
hehas soyo parts for dylt032d
1-203-239-6788
Posted on Apr 02, 2009
This set is a junker with no available parts avoid like the plague Pete
Posted on Aug 18, 2008
    Genius:
  • 1,153 Answers
Have you checked PTS 18008447871 ?
Posted on Mar 17, 2008
SOYO M# MT-SYTPT2627ABMS WON'T COME ON. LOOKING FOR A MAIN BOARD AND A POWER SUPPLY
Posted on Jun 18, 2009
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
Unable to turn on power.
Do you have any lights if you do not it's probably your power supply if you do it could be your power supply, signal board, t-con board, backlight inverters. In any case the power supply is te most likelly cause.
You can get parts at www.interliquidparts.com
Dec 10, 2011 | Soyo SYTPT3227AB 32 in. LCD TV
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
My Soyo Govideo LCD Television stop working, the red power light will not stay on.?? Its a 42 in LCD TV
Power LED light indication blinkings or completely dead?Yes,than the power supply board is the causes.That the board,where the power a/c cord plug in to it.Take the aparts,replaced the power supply board,will sold this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 20, 2010 | Soyo Onyx SYTPT4227AB 42 in. LCD TV
Need the code number to program a verizon fios remote to operate a soyo flat panel tv
try holding the tv and ok button 3 seconds when you release you get flashes now press 922 and then ok ..now press the fast foward button slowly but repeatedly till the tv turns off , when it turns off press ok ..tv flashes 3 times ..now press power and your good to go
Jun 21, 2010 | Soyo Dymond DYLT032A Television
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email parts@wde.com and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
Jan 19, 2010 | Westinghouse SK-32H240S Television
My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Soyo 32 inch lcd tv will not power up
Long story short:
Jul 12, 2008 | Soyo DYLT032D 32 in. LCD Television
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
Televison & Video Logo
1,313 people viewed this question
Top Televison & Video Experts
