The plastic door catch has broken can i get a replacement or do I have to buy a new door
  • 1 more comment
  • carrgo Jun 30, 2008
    Broken handle. Where can I get a new part and can I fix it without removing the unit?
  • shwayshway Aug 26, 2008
    The plastic door catch has broken and cannot release the catch holding the door shut. (I have the door open now). Can I buy and fit only the spring catch assemply or do i have to buy a new door.
  • Ron Coons
    Ron Coons May 11, 2010
    whats the make and model of the unit
I have had this problem and i purchased one from a spare shop in stalybridge tameside called empire spares the number is 01613386161 hope this helps.
Posted on Apr 15, 2009
How can I buy a replacement door for a 302 dishlex ?
I was looking for the same thing myself for our Dishlex 300 a few months back. Our problem was 1/ the handle wasn\'t releasing the door catch,
also 2/ the micro switch in the catch wasn\'t getting pressed down properly to tell the machine the door was closed, so the dishwasher wouldn\'t start. Both problems were related to the plastic ramp inside the door being worn where the tongue of the catch goes in.
We couldn\'t find one in NZ, so I made a tapered flat piece of wood to push the catch down between the main body and the door whenever we want to open it.
For the switch problem it was a bit harder - I opened up the plastic box at the top front of the machine (with the power off of course) and built up the plastic ramp that triggers the switch, using glue and then a file to shape it after the glue hardened.
I hope this is helpful.
Cheers.
May 26, 2014 | Dishwashers
Servis easi logic 1500
the doors can be dismantled and a new handle fitted. if you go to google. type in the make, model and end it with spares, it should come up with companies that supply parts. in the uk i use espares.
changing it can be fiddly but take pictures as you strip the door down so you get the pin, catch, handle and retaining spring in the right positions
May 01, 2014 | Washing Machines
DOOR CATCH NOT CLOSING, FEELS LOOSE. ELECTRONICS STILL WORKING - JUST SHOWS 'PLEASE CLOSE DOOR'. NOT SURE IF WORTH A REPAIR OR BUY NEW.
Most likely it is a mechanical problem with door safety switch. Unplug the unit from power! If you take the cover off, you will be able to determine if switch is defective by using ohm meter. You may be lucky and find a broken door latch or loose switch holder - look for lose plastic parts. !!! Do not attempt to bypass safety switch.
Feb 09, 2011 | Panasonic NNA554 Convection/Microwave Oven
The dryer door won't stay closed on my 90-series electric. Doesn't matter if the dryer is running or not. Have to keep the door closed by propping a weight bar against it. Any suggestions to get this...
There is a door catch made of plastic that holds the pin thats sort of arrow shaped on the door... The plastic catch is located on the front of the panel and can be easily replaced....Call the local repair shop/man to get the part....very cheap part maybe a couple of dollars at most... You should be able to remove the broken one with just a set of pliers and a screw driver...doesn't matter anyways its already broken right!! the new one will push and snap right in....Good Luck
Apr 20, 2010 | Kenmore Dryers
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
The door catch on my easi logic 1200 washing machine has broken
The door catch will have to be replaced, depending on model you can buy these from a repair shop for a few pounds.
You will have to open the machine to get to the door catch from inside.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
Remove the power supply as mentioned above, remove the top cover reach down inside and try to open the door, (BE SURE THAT THE DRUM IS TOTALLY EMPTY OR YOU WILL FLOOD THE FLOOR)
I can't advise exactly how to open the door from the inside, beacuse I do not know the make or model No.
If you are successful in getting the door open, the screws to remove the broken catch should be visible just inside the door.
Best of Luck!!
Jul 04, 2009 | Kenmore 4292x Front Load Washer
How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Interior Door catch broken
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
May 09, 2006 | Zanussi WJD1257S Front Load Washer
Broken interior Door catch
May 09, 2006 | Zanussi WJD1457W Front Load Washer / Dryer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
