Question about Dell Wireless 2350 Router
MTU failing for Xbox live
I have this router and every time i try to join Xbox live it says the MTU is failing
any suggestions?????
  • Nicky O May 20, 2008
    Yes, I have this problem. Can the MTU be changed?
  • DatGirl May 11, 2010
    Hi Mike, Are there any Xbox LIVE Certified dell router?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
I am afraid Dell 2350 Wireless Router is not Xbox LIVE Certified.
Check Microsoft Knowledge Base ID: 908882 - http://support.microsoft.com/kb/908882/
And
Xbox Live Compatible logo - http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Mike
Posted on Apr 15, 2008
SOURCE:
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
Sep 30, 2008 | Microsoft Xbox 360 Console
Mtu failing
ther is no probs with ur xbox it will com on today
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
Hello my mtu is sayin its failed
The MTU(Maximum Transmission Unit) failure when testing the xbox's connection can be do to a few things because Xbox live requires a minimum MTU setting of 1364. Sharing a slower internet connection with other PC's in the house can cause this error, The incorrect MTU setting in your routers programming can cause this error, The lack of firmware updates to your router can cause this error, an older modem from your service provider can cause this. Old or worn network cables and jacks and or RG(coax) cables if you have cable internet could cause this. Your Router or gateway could be incompatible with Xbox live.
Try a direct connection to the Xbox without a router and reset your modem before doing it. If your able to connect then you know its the router. If not you know its the modem or cables or jacks or even your Xbox if you havent tested it elsewhere.
You can tell your ISP to mail you the newest updated modem... sometimes they will have a guy just drop one off.
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
Open Questions:
SBCGlobAL CuStOMeR Care +*/{1^855^536^5666}NuMbER #[email protected]*,*% TOLL FREE SBCGLOBAL HeLpliNe NuMbER @[+1-855*536.5666] SBCGLOBAL eMaiL is one of the excellent service providers of various online services, SBCGLOBAL eMaiL mail tech support phonE number # {1,855-536*5666 }and its services are used by millions of users worldwide. to resolve all SBCGLOBAL eMaiL products. SBCGLOBAL eMaiL is an American multinational company which was founded by Michael SBCGLOBAL eMaiL using its company headquarters in Round Rock, United States of America. Contact SBCGLOBAL eMaiL for Setup & Installation SBCGLOBAL eMaiL Setup Support & Installation SBCGLOBAL eMaiL TECH SUPPORT number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for SBCGLOBAL eMaiL Connect, SBCGLOBAL eMaiL TECH Support Phone Number you'll be searching out SBCGLOBAL eMaiL Connect setup as well. So, here we're with all cthe setup process and for your to SBCGLOBAL eMaiL Connect. Get SBCGLOBAL eMaiL Setup Instant Support SBCGLOBAL eMaiL TECH SUPPORT Phone Number Usually, the setup TECHnique takes SBCGLOBAL eMaiL + tech + support phonE number # {1,855*536.5666 .u.S.A..SBCGLOBAL eMaiL mailtoll free number+SBCGLOBAL eMaiL toll free number, toll free number for SBCGLOBAL eMaiL, SBCGLOBAL eMaiL toll free phone, SBCGLOBAL eMaiL toll free, SBCGLOBAL eMaiL toll free, toll free number SBCGLOBAL eMaiL, SBCGLOBAL eMaiL support toll free+SBCGLOBAL eMaiL+toll+free+tollfree.SBCGLOBAL eMaiL
Oct 22, 2019 | Carrier Computers & Internet
SBCglobal MAil TelePHoNe {1-855*536*5666}#[email protected] NuMbER CUSTOMER SERVICE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
Amazon Prime Refund Phone^#^{+1^845481,1722} Number USA AMAZON PRIME Tech Support Number +1-845-481-I722 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA Amazon Prime Technical SuPpOrT Number +1-845-481-I722 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Facebook Computers & Internet
See all Dell Wireless 2350 Router Questions
Dell Wireless 2350 Router Logo
171 people viewed this question
Ekse
Clive
Clive
Alun Cox
