No sound - no video on TV
Mitsubishi color TV, Model CK-2602R
CANT SETUP VCR ON MY ORION TV, HOW DO I DO THIS?
  • Anonymous May 11, 2010
    Need more info. Are you trying to hook this up with cables. How are trying to hook it up?
    Novelist:
  • 236 Answers
If you're hooking your VCR via analog video input of your TV then check that the yellow colored video wire goes to yout TV video input, will also be colored yellow inside the terminal. The white and red color inputs are for audio. Likewise the output of your VCD will have the same colord code Yellow for video, red/white for audio (stereo). After setting this up, select your TV function to video in, be sure to check your video input channel as well if you're having more than one video input. Video 1 or 2 or 3. Make sure your VCR is powered up when you start to setup your TV function select.
if you're hooking your VCR to your TV via RF signal (over your TV tuner) You need to scan the right frequency to get it tuned to your TV channel. Cabling willbe via RF antenna input of your TV and RF antenna out of your VCR.
Posted on Mar 17, 2008
SOURCE:
Cannot get video on my Orion model VRO 211B
Could be a connection problem. Pins on plugs can become bent or damaged, sometimes it is the socket that the plug fits into that becomes damaged. Try a different connection lead.
Dec 26, 2015 | Orion VR0211B Video Cassette Recorder...
Where is the setup button on the vibe axcess 5 n 1 remote. None of the buttons say set or setup
Any one have the codes to the Mitsubishi TV ? I really need them bought a remote and my kids lost my manual , can someone please help
Aug 18, 2015 | Televison & Video
Retune a video player
do you still have your remote? You may need it to go to menu - setup - auto tune, that may help you
Sep 21, 2012 | Orion VR213 VHS VCR
I have a orion tv/dvd/vcr, model ftdv2004 i need
Hello
Three digit universal remote codes for Orion are:
035/ 121/ 135
Four digit codes are:
0121 0135 0035
Aug 26, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
When I hook my dvd player up using the red white and yellow cords, the sound will come in but not the video but I have no remote. Please please please help!
The yellow must go to the video and the sound L&R to the audio inputs. If there is no video after selection of the AV, then it is possible that the input video amplifier is faulty. If there is a second AV2 port then use it or else you might need a modulator to connecct vis the RF input.
Other wise the set must be opened to check for failure off the video amp, protection diode at the input.
Sep 21, 2010 | Orion1934 19" TV
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Just want the TV to play VHS video
check channel and check plugs
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
Usually secondary fuse blown and check horiz output xistor
for shorted = shorted flyback transformer............T.
Jan 22, 2008 | Televison & Video
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
