Question about Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 no picture, sound good
Screen went black, only one or two small flashes on power up. Approx. 1.5 years old. CCFL's or Backlight Inverter?
  • 1,665 Answers
If sound is ok, check appropriate video connection to make sure it corresponds to the audio connection being used. If connected with the component jacks on a DVD player, it may be necessary to access the DVD menu to select the component outputs or S-Video output.
Backlights in LCD screens are referred to as cold cathode fluorescent lamps (CCFLs). They are long, thin sealed glass tubes with an electrode at each end filled with gas and a small amount of mercury. The inner wall of the tube is covered with phosphor layers. The lamp is powered when high voltage is applied between the two electrodes, which causes the invert gas to ionize and display ultraviolet light.
The voltage is supplied from the inverter.
Posted on Mar 17, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 17, 2008
    I would try to measure output inverter voltage.(enough experience and special tools neened).
    It is better to take it to qualified repair shop.
    Good luck.
  • 306 Answers
If there is still sound its the back light inverter, if no power at all its the ccfl
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
May 08, 2009 | IBM ThinkPad T23 2647 Notebook
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo CLT1554 - faded to black...
This could be something simple or not... How old is the set? Is there any warranty left?
Apr 17, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo LCD TV DP32746 no picture
Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. for replacements.
Goodluck guys!
Mar 17, 2008 | Sanyo DP32746 32 in. LCD Television
No picture
Sounds like one of the CCFL's is failing.. (Backlight bulbs).. Some use multiples and others have singular.
Feb 29, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo lcd 32" vizion integrated hdtv
I have this tv as well with the same problem. From the research I've done, one of the 16 ccfl's(backlight bulbs) goes bad and they all will not come on then. I have not been able to find a replacement ccfl for this particular tv. The ccfl size if 3mm x 711mm. I have a feeling the scope of this problem is very large with this particular tv and this forum represents the tip of the iceberg. Sanyo unfortunately makes a piece of junk and we have that piece of junk sitting in our homes with no good solution other than to say, dont waste your money on another Sanyo tv.
Jan 09, 2008 | Sanyo DP32746 32 in. LCD Television
Sound, No Picture
I took mine in to the Sanyo authorized repair shop and they found the screen itself was bad. Sanyo sells the new screen for $1100, almost double what I paid for it. The repair tech said they do that intentionally.
Oct 21, 2007 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
379 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
