Question about Olympus VN-3100PC Digital Voice Recorder
Retrieving data Is there a way to retrieve erased data from an Olympus VN-3100 Digital Voice Recorder? It is not the PC version of this model.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
No way to retrieve any erased message
Posted on Aug 20, 2008
SOURCE:
I just removed the batteries of my olympus vn-3100- shows ERR
you should replace your old battories put the new battries in it. carefuly.
Apr 26, 2010 | Olympus VN-3100PC Digital Voice Recorder
My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
I deleted a recorded file by mistake from the DWP vn-480 series and am trying hard to retrieve it somehow!! Is there any hope of retrieval???
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Jun 08, 2009 | Olympus VN-480 PC Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Jan 21, 2009 | Olympus DS-30 Digital Voice Recorder
ERASING FOLDERS FROM DIGITAL RECORDER
hold down the stop and erase buttons on the recorder for about 3 secs... comes up clear, arrow over to yes..
Sep 08, 2008 | Olympus VN-240 Digital Voice Recorder
Olympus VN-3100PC Voice Recorder Problem
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Jun 25, 2008 | Olympus VN-240 Digital Voice Recorder
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Jun 23, 2008 | Olympus VN-3100PC Digital Voice Recorder
Error message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
May 26, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
154 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
