Hello, i have a chevrolet dually, the carrier bearing, in mine was doing this, i took it apart, pulled both driveshafts apart then took carrier bearing off, the bearing inside was dry, plus they had a bblue look to them, bearings was bad, plus rubber around the bearing was dry rotted, there is know way of greasing these bearings because they are sealed, i pull bobcats, tractors, with mine if you use it for a lot of heavy pulling, they dont last a long time, chevrolets carrier bearing is all made together, bearing and rubber is made together, on mine, seems like i paid about 35.00 dollars for mine, spray some wd-40 around driveshaft where it goes into bearing, i had to take a hammer to mine to get it off front drive shaft, it was stuck pretty bad.
