Question about Toshiba 57H82 57" Rear Projection Television
57H82-no picture from DVD input
I have tried components and s-video to hook up dvd player to this Toshiba 57H82. I get good audio, but now no picture. Any ideas? (DVD works fine on other tv's.)
  • 4,234 Answers
Make sure that the DVD is the only component connected to that particular input. In otherwords, if you have the typical AV cable connected to video 1 and the S-video cable also connected to video 1, the AV setup will be the one that works.
Dan
Posted on Mar 17, 2008
  • 979 Answers
How does line out from the DVD player do? I would suspect a bad preamp/buffer on the TV...accordianman
SOURCE:
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I have hooked up the composite video and rca stereo cords to DVD player and TV. Sound but no picture even after I tried pressing video on remote, and correct input on TV remote. Do I need an component...
yes to use component input you need the component cable they are very different from rca cables
good luck with it
sonic boom electronics australia.
Apr 21, 2010 | GPX DH109B DVD Player
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
No DVD Picture
you need to assighn the input for the component video page 78 of your manual will explain how
Dec 28, 2007 | Yamaha RX-V661 Receiver
Toshiba 57H82 57" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
