Need to remove pump from kudp01 kitchenaid and check-have removed all parts but can't figure out how to get pump cover off and plastic housing covering grinder, pump, etc
Holding the center nut for lack of better word and unscrewing the wash arm, the next piece will require turning clockwise while pulling up on the plastic lock tab holding to up spout for water supply, gives you access ot 5 torx screws, after that theres 2 more torx screws giving you access to the chopper/ impeller area, thats as far as youll be able to go.
Hi
Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller.
Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat.
Hope this helps...
Please post back for any further assistance.
Daniel
I have the same problem. I get all the screws out, but the grinder cover will not lift off.
-Ted
I'm following the posted advice to get into the bottom of my Kitchenaid dishwasher. So far, I got the wash arm off and removed 3 screws. Can't get to the next two screws yet. I'm working on the next piece: "the next piece will require turning clockwise while pulling up on the plastic lock tab holding to up spout for water supply" I've pulled up on the plastic lock tab attached to the upspout, but I can't get anything to turn clockwise. I've tried to turn everything I could imagine, can someone give more guidance on what to turn? (I just need to clean out all the hardened, crusty soap that's under there.) Thanks.
