Question about Motorola Mobility Q9m Smartphone
Hard re-boot I need to do a hard reboot of the phone but cannot access my start menu. Is there a way to do this?
  • Anonymous May 10, 2008
    I put a password on my phone and put it in but it wont work... I would like to reset it but I dont want to loose my numbers, if there is a way can I do this, or if not how do I do a hard reset?
THANK YOU!! This solved a different problem I had (the start menu little logos had dissappeared).
Posted on May 24, 2008
1) Power Off Phone
2) Hold center (select) button
3) Power On Phone while holding button down
4) Master Reset menu should come up
Posted on Mar 22, 2008
Ntldr is missing
Try to reboot your computer and push F10 or F12 for boot menu. When you enter the boot menu find and select hard drive or C/: in the menu and continue to start the computer. If that doesn't work, your hard drive may be non-functional. I hope that helps.
Mar 16, 2014 | Acer Aspire 5315 Notebook
How to enter boot menu on IBM thinkpad x41? I am trying to start with usb
Restart your computer with the USB drive connected, and press the blue "Access IBM" button on your keypad. Select "Startup Utility" and go to "Boot Order." Change "USB Device" to "Primary," save changes and exit. When your system reboots, it should boot from the USB drive.
Dec 30, 2012 | IBM ThinkPad X41 Notebook
Can not boot up computer
possible your hard drive
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Media test failure message. Reboot and Select proper boot device
hope this helps
Non system disc or disc error fix
Hi, do you have a floppy disk, cd or usb stick inserted in your computer? Try removing such items and reboot as it may be trying to read these before the hard drive.
Check the boot order, when you first turn on your computer, access the BIOS menu (may need to push Delete, or one of the function keys eg F2, F8, F12 etc).
Check the boot order to ensure the correct hard drive it listed. Try moving the hard drive to the first option and reboot.
If removing any cd, usb stick etc doesn't help, try removing the hard drive and see if you can access it from another computer. If you can't access it, your operating system nay be corrupt and you may need to reformat.
Jul 28, 2011 | Intel Motherboard
How do i reboot or recover my nb505 toshiba netbook
Reinstall Windows from a Disk
1 Turn on your Toshiba . Insert your recovery disk or the original Windows operating system DVD
into the 's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba . In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba . In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba NB505N508BL 10.1" Intel Atom...
What web site can i use to get a reboot cd for my computer
You can make a boot cd on most any computer that should work on your computer. If your looking for a restore disk only the manufacturer of your computer system can provide that, you would have to go to their website to see what options they offer. If you just need something to repair a Windows boot problem use your Windows installation cd. Most the major companies put a restore partition on the installed hard drive you can access by pressing F8, F10 or F12 while the machine is starting up. Sometimes you have to go into the system bios menu to get this option, HP computers do this. Press ESC then from the menu press your desired option. If your BIOS is not set to check for boot media in the CDROM before the Hard drive you'll have to change that. I recommend you set the boot order to Floppy, CDROM, Hard Drive then if the option is there the USB would be your last selection in the order.
Oct 11, 2010 | Computers & Internet
Disk Managemet says my hard drive "Not Initialized". Windows cannot see it in My Computer. How can I recover my data?
let me get this straight... you can boot-up and windows does start. So your system is seeing the hard drive well enough to get you into window, but once there it refuses to see the hard drive it is based on??? Or by some chance is there a second hard drive which you are attempting to access? If that is the case you need to #1 see if it listing in your bios menu which you can access during start up, but even before that you need to make sure that the second HD is jumpered to slave mode if your running off the second hookup of a dual IO cable, if on the other hand you have it plugged into the second plug on the motherboard make sure you have it set to master. If that is all set then.
#2 reboot your computer and log into your bios menu look to see if your HD is listed if not using your +/- keys once you have the first open slot highlighted use the +/- keys to run through you options when you see auto check your bios control legend on the bottom hit the button which activates it your HD should show up in that selection area.
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I cannot get my gateway gt5028 to reboot,, i have no disc,, people tell me yiu can reboot and get computer back to normal without one,, help!!
there are 2 things about reboot that is the reboot from the bios or reboot from the windows... if you mean you can't reboot and there are no hard disk as your primary hard disk try to check if the bios detected the hard disk. by pressing Delete key when you start to reboot the computer... make sure there are someone with you who knows something about the computer BIOS. if not keep in touch.. in Main menu in BIOS you will find If the computer detected the hard disk, if not detected try to check the IDE/SATA cable or Power Cable of your hard disk. Check if that hard disk is the first boot in the Boot section of the BIOS, if not then change the Hard Disk as your first boot.. That will help you boot your computer properly in windows..
Dec 05, 2008 | Gateway GT5028 PC Desktop
Reboot
Hi satiewe, no not you're CD. You'll need to enter the notebook's bios. How to get into the bios? Right after you press the power on button, start pressing the delete key every two seconds. The bios main menu should load. If pressing the delete key fail to load the bios menu, try again & press the F2 key every two seconds. The main menu will look like this:
1583ec1.jpg Look at the bottom of the menu & there are instructions on how to move about while in the bios. Go to the title, Advanced.
Listed to the right of; [PATA Primary Master : xxxxx] Where xxxxx is the model number of the hard drive, (Ex: ST80325B). Write this number/letter down. Than go to Boot .
Under boot is, Boot Device Priority. The normal order should be;
1st boot device, [floppy]
2nd boot device, [CD-ROM] - model name.
3rd boot device, [Hard disk drive]? The name of the drive was listed at the main menu as, Pata Primary Master (What you wrote down is what must show here). Than save the bios change & exit. The system will restart. If you placed the correct drive in the correct order you're system will start up.
Good Luck!
Mike
Jun 26, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Motorola Mobility Q9m Smartphone Logo
145 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
