Question about NEC ND-3540A DVD RW Dual Layer Burner
NEC ND-3540A DVD RW - problem with erasing RW DVD
In past months I have problem with my NEC. I cannot erase rewritable dvd. I downloaded the latest firmware 1.04 but the result is the same.
Please help!!
  • Eugene Schwarz May 23, 2008
    Same problem, my NEC DVD-RW ND-3540A will not erase. It tells me the disk is damaged. Even brand new never used out of the container are rejected. Tryed both Nero and Roxio. Help???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Try downloading this cdrw soft ware it works graet you can write rewrite and play software dvd 's evrything www.slysoft.com lala linda
Posted on Jun 03, 2008
NEC DVD_RW ND-3540A
You need to replace your DVD RW drive.
Sep 02, 2012 | Acer Computers & Internet
I bought 2nd hand NEC ND-3540A DVD-RW CD-RW DUAL LAYER REWRITER IDE for the replacement of Philips DVD R/RW Drive (DVD8631/96). However this ND-3540A will cause the ploblem of not only unworkable, but...
since you have been inside your computer and moving leads about some of these may be old and deteriotaed then any movement might
(crack break the circuit even if its slight)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 10, 2011 | NEC ND-3540A DVD RW Dual Layer Burner
I Have A NEC ND-3540A DVD+R/RW Dual Layer Burner, It would not burn on a +R DVD What should I do
First thing to try would be a different brand of disc, there is never any guarantee with which brand of disc working with any specific DVD writer.
If you have tried different brands of disc and the DVD +R still does not work, I would reccomend visiting the manufacturer's website and downloading a firmware update for you specific DVD drive.
Note: Be very careful updating the firmware on the DVD drive, if the wrong firmware is used - or the firmware process not done correctly you can damage your DVD drive.
Aug 15, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Nec nd-3540a dont recognize cd's
hi,
1. check your cd is that good are scarbbed one.
2. clean the lense, with lense cleaner
3. try it again cd
4. check your cables for loose contacts
thanks
ehsanullah.
Jun 15, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
NEC DVD-rw Can't read CD disc
You have to download aspi drivers and force aspi18. I had the same problem and this solved it!
Sep 23, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
I can't burn anything ...
download this its recommended for sp3 then try to burn again
http://www.divx.com/
Sep 09, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Nec nd-3520a
try downloading www.slysoft.com you burn read and rewrite almost everything you can test drive it for 20 days or so and if you want to buy it it is very cheap. lala linda
Oct 31, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
Cant play "Nashua" DVD+R dual layer CD
Try going to www.slysoft.com thier dvd program is supper you test drive it for 20 days and then buy it for a small price lala linda
Sep 16, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
NEC ND-3540A DVD RW Dual Layer Burner Logo
181 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
