Question about Refrigerators
Freezer temp seems high and wont come down bottom of freezer seems cooler
    Problem Solver:
  • 6 Answers
You fan motor is bad, also check if you have a little fan in the midle of the freezer maybe is bad to
Posted on Jan 22, 2010
Refrigerator freezes all foods even on other shelves
Posted on Mar 18, 2008
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Hi
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer runs constantly,seal is okay,frost free,have tried lowering the temp,food stays frozen. zeecudaboro@tds.net
It seems to me that the thermostat is no longer sensing temperature. IT will either stay on (it controls the compressor) or wont come on at all when it becomes a problem. You can order one thru sears.com if there is not a appliance parts store nearby. To check before buying, heres what you do. You need to know the temperature (use a thermometer that reads below zero). it has to be at least 10 degrees or cooler. if it is then turn down thermostat dial to 1. if it shuts off then the thermostat is ok. if it doesnt turn off (the compressor) replace t'stat. let me know the temp. and if this works for you hope this was helpful...
Mar 30, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
39 ltr engle fridge freezer wont shut off when at temp
hi,
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer always about same temp as the upper refrig section
Check those coils underneith. They are making the machine work harder IF they are dirty. They may be full of lint and cobwebs. All that needs to be removed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
