Paper jam I've got a seemingly unreachable paper jam, in the rollers above the paper tray. I've opened everything i can
  • 3 more comments
  • Padrino1 Mar 22, 2008
    paper jam and cannot remove from rear of printer. By removing the cassette in the front of the machine and laying the machine on it's left side, I cannot see any paper jammed. I can see it jammed in the rear only. What else can I do without bringing the machine in somewhere?
    George DeBenedetto
  • eclectic Mar 22, 2008
    Canon d860. Paper is jammed at rollers of output tray. Was able to pull out some paper with needle nose plier. Cannot reach area. Tried some dismanteling but no luck.
  • cindy66 Mar 24, 2008
    paper jam/ open back door? How?
  • speedy01 Apr 03, 2008
    Had paper jam message appear on brother mfc-210. Remove paper jam from printer and open all door and still get paper jammed message. turn computer off and printer to reboot and reset and still can not get printer to work. No matter what I do this problem persists. I just want my printer to start working like when I purchase it. I can't afford to purchase another printer when I know that last week it was working just find and one day it just up and stops working for no reason. there was no paper jammed in the system but the error message said there was. We also reconfigure the control panel for the printer and it still shows the document ready to print but a paper jam message appears on the printer message display window. We just bought a new computer in Jan 2008 and the computer is operating find. The printer was also operating just fine and now it is not working properly. I want a new printer and as a valued customer we deserve it.
  • starzy21 Apr 07, 2008
    have same problem..how did you fix it.
    Sergeant:
    Champion:
  • 210 Answers
try this....
> unplug power chord
> open the rear access door
> remove the paper jammed
> close the rear access door
> plug the power chord
> try to copy
thanks and regards
agnel
Posted on Mar 18, 2008
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Jammed paper...
Try removing the Toner/drum unit and see if paper is there. Also check the rear access door to see if paper is stuck in the fuser.
Sometimes you will get a jam where the paper has not even left the paper tray. Try removing the paper tray and cleaning the paper feed roller with and cloth dampened with a little water. The roller is located just above the center of the tray.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Feb 03, 2009 | Ricoh Aficio AP410N Laser Printer
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
922 people viewed this question
jasbo
jasbo
