Question about Kenmore 24902 Top Load Washer
How hard is it to change the hose connetors on the washer
How do i change the connectors to the back of the washer where the hoses connect. I broke a hose off a while back and somehow i messed up the grooves that are on the washer.
  • Anonymous Dec 03, 2008
    Is it hard to replace a hose on the washer????
    President:
  • 331 Answers
The washer valve assy. was damaged. The only solution is to replace the valve assy. period. No other way around it... sorry.
Posted on Mar 24, 2008
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
Water comes out of connetor that hooks up to washer
have you changed rubber washer in hose? look for crack in fitting
Jul 06, 2011 | Haier HLP21E Top Load Washer
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Washer hose connector is broke can this be repaired
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
You should be able to see a number of hoses, connectors etc that will replace your broken connector.
Mar 30, 2010 | Kenmore 98702 Stacked Washer/Dryer
I HAVE A G30500HR PRESSER WASHER AND ACCIDENTLEY
Hey mate,
You should definately be able to get one of these at your local Karcher dealer, Ive worked at a karcher dealer here in australia and you can get any part you want for them...
Brad:)
Jan 02, 2010 | Karcher G3025OH Pressure Washer
Husky powerwasher replacement part
Hard to find hose repairman,maybe radiator shop,but you will find you will probably have to by new,you would need special high pressure hose crimpers,someone like hydrolic line repair.
I know.... Please rate a fix ya Thanks jj505
Apr 11, 2009 | Garden
Removing the windshield washer reservoir in a 2002 Chrysler T&C
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the engine fresh air housing inside the engine compartment.
  3. Disconnect the washer hose at the in-line connector forward of the cowl grille so that the in-line connector remains with the washer hose from the fresh air plenum.
  4. Disconnect the washer hose from the hose clip located on the front fender side shield.
  5. Remove the filler tube screw.
  6. Hoist and support vehicle on hoist or jack stands.
  7. Remove the right front wheel and tire assembly.
  8. Disconnect the left right front wheelhouse splash shield and move aside.
  9. Drain washer fluid from the reservoir and into a suitable clean container. This can be done by disconnecting the windshield washer hose from the front (outboard) washer pump and allowing the washer fluid to drain into a container through a temporary jumper hose connected to the front washer pump.
  10. Disconnect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the release position, then, depress the black tab and pull the connector off the pump or sensor.
  11. Remove the two reservoir mounting screws.
  12. Disconnect the reservoir from the body mount by raising the reservoir upward slightly and then down so that the reservoir filler neck and front washer hose pull through the opening in the front fender side shield.
INSTALLATION
  1. Push filler neck and front washer hose through the opening in the front fender side shield. Connect the reservoir to the body mount by lowering the reservoir down.
  2. Install the two reservoir mounting screws. Torque screws to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  3. Connect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the closed or locked position.
  4. Assure that washer is properly routed to prevent pinching and possible inoperative washers.
  5. Connect the left right front wheelhouse splash shield and move aside.
  6. Install the right front wheel and tire assembly.
  7. lower vehicle from hoist or jack stands.
  8. Install the filler tube screw. Torque screw to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  9. Connect the washer hose to the hose clip located on the front fender side shield.
  10. Connect the washer hose at the in-line connector forward of the cowl grille.
  11. Install the engine fresh air housing inside the engine compartment.
  12. Connect the battery negative cable.
  13. Verify system operation.
Apr 01, 2009 | 2002 Chrysler Town & Country
No Suction ARGH!
on the backside you will see a clear type of hose towards the bottom coming up the back.thats your intake hosethats whats clogged.you will see a connector that its connected to.on the connetor there is a screw,take the screw out and pull the connector away from the cack.take a coat hanger and bend the end so its round and work it down into the intake hose ,you should be able to push the clog out through the bottom.be carefull not to puncture the hose
Mar 15, 2009 | Dirt Devil Featherlight Bagless Upright...
Slow cold water
1.) turn off water valve that supplies cold water to washer.
2.) unscrew the cold water hose-type connector immediately next to the set of 2 water connections in back of unit.
3.) look into the hose you just removed or into the water connector on machine. you will find a metal screen (like a window screen) that is cone-shaped...if none found then remove hose connection at other end of same hose...remove it and then clean it thoroughly and then re-assemble all.
Nov 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 24902 Top Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
