Question about Samsung SGH-s105
Malfunction? always display "insert sim card" even with sim
  • Samsung Master
  • 13,434 Answers
Make sure the phones sim reader pins are all clean and they touch the card. If after cleaning and useing a pin to rise the pins the phone still doesnt work.
Then Id suggest you take the phone to the shop where you got it for repairs or to some other professional for repairs / analysis.
Posted on Mar 17, 2008
SOURCE:
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Tip
How to correct sim card error / insert sim card Procedure to follow Step 1:...
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Jan 19, 2010 | Cell Phones
Sim card promblem
Procedure to follow
Take care
May 07, 2010 | Pantech Slate Cell Phone
Sim card
Procedure to follow
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
No SIM card inserted
blow the hole of the slot theres is probably dust and dirt blocking it from going through
Jul 27, 2009 | HTC Tilt 8900 Smartphone
It alway diplay No SIM Card inserted even when there SIM Card in it.
Solution, try putting a paper behind the sim card before placing it in the cellphone. The paper adds thickness to the sim card and makes it touch the connectors in the cellphone.
May 02, 2009 | Cell Phones
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Mar 27, 2008 | Nokia 6270 Cellular Phone
SE K750i displaying 'insert sim' even though sim is inside.
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it. for any queries mail to [email protected]
Sep 01, 2007 | Sony Ericsson K750i Cellular Phone
Samsung SGH-s105 Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
