Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
I just purchased and had installed an alpine pdx-1.1000 amp. powering 2 12" jbl's. while the owner was demonstrating this to me, we had it going loud, and it blew its 4 fuses. once he replaced the fuses, it worked fine again. my question is, are there some performance fuses or more powerful ones that i can use to prevent the fuses from blowing. the ones he put in, were fuses that had the number 25 on them, and there was 4 of them. any help is appreciated. dave.
  • bigconanman Mar 18, 2008
    i have dual 12 inch jbl's. i beleive they are 6 ohm. and the place that did the work, are very well known, theyve won numerous awards, and world championships. so, i know they know what they are doing. not a doubt in my mind about that.
  • bigconanman Mar 19, 2008
    ok, the name of my sub woofers are JBL W12GTI they are Dual 6-ohm voice coils Power handling Peak: 4,000 watts
    Power handling RMS: 700 watts
    i got this info from the website for the woofers. maybe this info helps.
    Sergeant:
  • 300 Answers
Technically, the manual says the amp should have 20A fuses, so by putting 25A fuses in, you've allowed more current to get to the amp before the fuses blow than recommended. I'd be more concerned about why the amp is blowing fuses.
If the subs are single 4 ohm voice coils and wired in parallel, you're fine. If they're dual 4 ohm voice coils, and everything (subs and voice coils) are in parallel, you're putting a 1 ohm load on the amp, which it's not rated for.
Posted on Mar 18, 2008
  • Tygh Duval
    Tygh Duval Mar 19, 2008
    I'm not doubting the installers capabilities. I'm just brainstorming reasons why the amp might be blowing fuses. In my opinion, swapping fuses for higher rated fuses is not a safe thing to do, but hey, to each his own. I guess I'm just more "by the book".
    Sometimes there are "slow blow" versions of some fuses that take longer to blow at their rated current. This allows some spikes to occur without blowing the fuses immediately. Unfortunately, I'm not sure I've seen the type of fuses used on amps in the "slow blow" flavor.
    I'd be interested in knowing if the subs are dual 6 ohm.
  • Tygh Duval
    Thanks. Nice subs, btw. The only problem I see is if the DVCs and subs are paralleled. If so, that's a load of 1.5 ohms on the amp. Since the amp is rated for 2 ohms, 1.5 ohms could overdrive the amp, causing the input fuses to blow. I'm sure there are amps out there that are rated for 2 ohms but still have a little "headroom" for lower impedances, but others get real unhappy, real quick.
    If the installers wired the subs DVCs in parallel and the subs themselves in series, that'd total 6 ohms, which the amp could do (although you might not get full power from the amp).
Alpine amp not working.
possably, did you get it professionally fitted? they have lifetime warranty on install,
Apr 22, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I resently installed an alpine amp and now my speakers are whisling along my accelarating. wat can i do about that
That is called engine noise, usualy happens when you run the RCA signal cables down the same side of the car as the power wire for the amp. if you have the power wire, and rca cables separated, and you are sure you have a good ground for the amp, go get a ground loop isolator from Best Buy, or any place that installs car audio. some people call it a rca noise filter. it plugs inbetween the rcas and the amp and it should take care of the noise. Hope this helps.
Aug 21, 2009 | Alpine PDX-5 Car Amp
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I have an Alpine CDA9884 the deck has been in my car for about 3mos and I've been listening to my speaker from the power put out by the deck itself. I have installed an Alpine PDX 4.100 and a PDX 1.600....
the manual says that you should power off the internal amp if using external amps. Maybe you need to do this to get power going through the remote turn on?
in the menu its "POWER IC ON" you need to change it to "POWER IC OFF"
hope this helps?
Phil
Oct 26, 2008 | Alpine Car Audio & Video
Alpine pdx-1.1000
what is happening is the amp can draw the current. u need a capacitor
Apr 11, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
165 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
