Question about Hitachi 42HDT20 42 in. Plasma Television
Hdmi Do I need an HDMI cable to get HD? If so, where is the connection on this tv (Hitachi 42HDT20)?
    Master:
  • 518 Answers
You can get HD using "Component" video connections.
Geno
Posted on Mar 17, 2008
SOURCE:
Can I connect my fire hd 10 to my tv using a cable.
It seems as if it is possible to connect your Fire HD 10 to a TV via a HDMI cable. In order to do this you will either need:
  • Amazon HDMI adapter for fire tablets
  • Micro HDMI/ USB to HDMI cable
Here is a helpful article with ways to connect to a TV and links to the types of adapters on amazon.
How to Connect Kindle Fire to TV
Amazon com Amazon HDMI Adapter for Fire Tablets 4th Generation Kindle Store
Amazon com AmazonBasics High Speed Micro HDMI to HDMI Cable 3 Feet Latest...
Apr 02, 2016 | Amazon Kindle Fire HD
For my 50v500 tv built in 2004 is there an HDMI cable or adaptor to connect for signal?
If there is a socket at its back marked as HDMI, the set should have capability to receive HDMI signals, provided the HDMI firmware has been installed to it successfully. You can connect it with an HDMI cable, with any other external equipment having HDMI output, and select the TVs' input to HDMI.
Electro help
Jul 03, 2014 | Hitachi 50V500 50 in. HD-Ready LCD...
How do i get the hdmi working
HDMI start by putting one end of the HDMI cable in the HDMI socket on the tv, then the other end in the HDMI socket on the device your are going to use. It can be a decoder, an apple tv or something else that needs an HDMI connection to the tv to work.
Secondly find the remote control and push the input button then there should be a picture on the screen with different possibilities for input. Click where it says HDMI.
You should be connected now,
kolbrub
May 25, 2014 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi L42S02A no sound through HDMI
I've had a few HD TVs that you could disable/enable individual ports on the TV in the Settings menu. Good luck.
Jan 28, 2018 | Hitachi L42S02A 42" Multi-System LCD TV
We bought a hitachi 50hxt 16u tv and are unable
tried to replace the HDMI cable then set the right source.check also your box which not working.
Nov 02, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I connected my dvd player to my hdtv and its only in black and white. I have adjusted the settings numerous times and it isnt fixed. the cables are all in the right color matching holes..how do i fix this?
Ur RCA AV component cable set might bad replace it with another RCA set of cable or tv have HDMI and also DVD player too for HD connection by a HDMI cable through HD hub?Buy and used a HDMI cable connect tv and DVD player to together one HDMI cable for a better functions.
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI connectors..Where are they?
Greetings Jazzne1,
Looking at your users manual your television is "HD-Ready" which means it will be able to display images in an high definition resolution. But because of the age of this unit HDMI was not a standard format to provide the HD signal.
You should be able to connect an HD video source to your television with the Y, Pb, Pr Component connectors. The downside to this is most standard up-scanning DVD players available will only up-scan through the HDMI connector, but you should be able to connect HD digital broadcast boxes and cable and satellite services with these connections
Regrettably there really isn't a way to install an HDMI connector on a television "after market".
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 03, 2008 | Hitachi 43FDX01B TV
Hitachi 42HDT20 42 in. Plasma Television Logo
144 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
