Question about HP DeskJet 6122 InkJet Printer
Colour printing problem
I can't seem to get it printing properly in colour - I thought the ink was out so I changed the cartridge. However, the new one is printing just as badly as the old one - in streaks instead of lines. Any suggestions?
  • 22 Answers
Clean it...
if u have cold air blower...
Posted on Mar 17, 2008
SOURCE:
Problem With Kodak Colour Ink Cartridge I bought a Kodak colour ink cartridge as it was saying replace colour, l installed it but it was still saying "replace colour" I thought maybe the cartridge cou
the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t
Mar 28, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
I have just fitted new cartridges although it was only the colour one which needed renewing I thought! However it wuld only print out in red/pink shades so I changed the black cartridge to be on the safe...
I have personally encountered similar problem in my work. There is no problem with your printer, No need to go to your suppliers yet.
Sometimes when either of the inks overflow at the nuzzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning that yellow printing red back to printing truly yellow. Bring out your colour cartridge. Peel off the seal covering top. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nuzzle. Clean off the ink. (At the nuzzle do not rub only dab). Now press a piece of folded tissue to the nuzzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
Hp psc 1350 colour printing problems
Sir,
Check this link to solve the problem
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 28, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Fixed new colour cartridges, and they are saying that the colour cartridges are empty and they are full
please check whether the printout is coming proper when you give a print.
if its coming proper the cartridge is proper.this message is shown because in the printer there is a sensor which detects where there is a ink in the cartridge or its empty.so if the printouts are coming properly the sensor is bit moved from its orignal position or the sensors are damaged and became faulty to detect the ink in the cartridges.
so you use the cartridges let it detect no ink print out will come till the end of the ink.
or if still the prints do not come try changing the cartriges .
Sep 24, 2008 | Televison & Video
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet 6122 InkJet Printer Logo
74 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
