Convergence trouble philips mod 51pp9303h/17
Convergence trouble philips,mod 51pp9303h/17,need parts number for convergence ic.
  • Anonymous Aug 13, 2008
    where i can find a new frayback tranformer
  • Anonymous Mar 31, 2009
    when I try to converge the picture it looks distorted on the top and bottom of screen. it looks like its warped. and bright colors glow
  • 8,617 Answers
STK392-120 you will need to replace both of them
Posted on Mar 17, 2008
Adjust color on philips 51pp930h-17 tv
done with the remote in the customer menu under convergence.
Apr 29, 2012 | Philips 51PP9303H Rear Projection...
The display on my phillips hdtv 51pp9303h
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Philips 51PP9303H Rear Projection...
Repair man said my philips tv model #51pp9303h/17 needs coupler.
Tries Shopjimmy.com,Partstore.som,or Ebay.com.These Websites have refurbish old and new tv parts.
Dec 28, 2009 | Televison & Video
Replacing STK-392-120 ICs on Philips TV
Ok, I can tell you not to remove the circuit board--best way with this set is to put the entire chassis--all three circuit boards in the"SERVICE" POSITION.
LET ME KNOW IF YOU WANT TO KNOW HOW TO DO THIS---YOU ARE RIGHT--YOU TRY TO REMOVE THE BOARD WITH THE CHIPS--SEVERAL OR ALL THE PLUGS ARE NOT MARKED WITH NUMBERS--THERE IS A SIMPLE WAY TO DO THIS.
LET ME KNOW AND i WILL ASSIST YOU.
Oct 13, 2009 | Philips 51PP9303H Rear Projection...
Philips Projection HDTV 51pp9303h/17
STKs in your set should be on same board that has tuners on it board you connect cable too.If different model they will be on board to very right end STK ICs are big black chips Two of them together.will have part number on them.
Jan 03, 2009 | Televison & Video
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
Need Parts Number For Flyback In Philips W/S TV Model # 51PP9303H/17
If you are not sure how to find/repair/replace the HVG yourself goto www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Oct 16, 2008 | Philips 51PP9303H Rear Projection...
51PP9303H/17 convergence repair help
I would change all convergence IC not just the one that holds the red. You will need the schematic to get the resistors location.
May 01, 2008 | Televison & Video
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
676 people viewed this question
Top Televison & Video Experts
Electro Med Services...
